Author Topic: Is it the Solenoid?  (Read 9632 times)
Offline adr3naline
  • adr3naline
    • adr3naline
Is it the Solenoid?
« on: February 27, 2012, 10:56:56 PM »
So, I believe my solenoid is bad... 1979 CB650.
I've jumped the solenoid with a screwdriver and my starter motor turns over. But I don't get anything with my starter switch. When my ignition switch is "ON", I get power to my starter switch (black wire), and then also when I push my starter switch I get power back to my solenoid (yellow/red wire)... but nothing.
Are there any other tests I need to do? I see other solenoid tests suggest checking the ground connection of the solenoid, but I couldn't see any specific ground line coming off of it. Am I wrong?
(I'm trying my best at electrical stuff... but I need your help).
Thanks!
2006 Yamaha Warrior
1982 CB900c
1979 CB650
Offline w1sa
Re: Is it the Solenoid?
« Reply #1 on: February 28, 2012, 02:07:21 AM »
The starter relay circuit requires starter button power to the y/r (which you seem to have) and, a ground path from the solenoid/relay. That is the green/red to the neutral switch and also the clutch switch. That's why the bike must be in neutral or clutch pulled to allow starter motor action..................check the ground wire paths to the neutral switch and clutch switch for proper/clean connections and if that's good... also check the circuit for continuity.
Offline lucky
« Reply #2 on: February 28, 2012, 06:46:15 AM »
If you activated the solenoid with a screwdriver it is not the solenoid.
It is the start button more than likely. very fragile and ifffyyy.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: February 28, 2012, 07:17:40 AM »
Odds are the starter switch is the problem, +1.
Offline adr3naline
  • adr3naline
    • adr3naline
« Reply #4 on: February 28, 2012, 07:37:24 AM »
For now I just tested the starter switch with a light test, and the wire going back to the solenoid lit up... so maybe I just need to do a voltage test now? To see?  How could it be the starter switch if my yellow/red wire has no power, then when I press it it gets power?
2006 Yamaha Warrior
1982 CB900c
1979 CB650
« Reply #5 on: February 28, 2012, 08:39:18 AM »
Wait, the screwdriver bypasses the solenoid so you may have a bad solenoid if the starter switch passed a light test.
Did you get the bike to fire up (as in run) with the screwdriver bypass?
Offline adr3naline
  • adr3naline
    • adr3naline
« Reply #6 on: February 28, 2012, 08:47:14 AM »
I got it to turn over, but I didn't have the tank on so I didn't go any further.  It would crank with the screwdriver bridging the posts.
The only thin the starter switch does is turn the neutral light on when I push it, and back off when I let go. The solenoid doesn't make any sounds at all.
2006 Yamaha Warrior
1982 CB900c
1979 CB650
« Reply #7 on: February 28, 2012, 10:11:04 AM »
If it does not make a clicking noise at least then the solenoid is probably bad.
Offline adr3naline
  • adr3naline
    • adr3naline
« Reply #8 on: February 28, 2012, 10:49:48 AM »
I just ordered a new solenoid... We'll see what happens I guess.
2006 Yamaha Warrior
1982 CB900c
1979 CB650
Offline bobth1019
« Reply #9 on: February 28, 2012, 03:31:24 PM »
Interesting, I was just about to post here with pretty much the exact same set of issues.
With test light I get juice across the start button and kill switches and if I run a jumper wire across the starter relay B and M terminals the starter will turn over. Lights work so that much is good just no starter connection from the start button. I pulled apart the switches and cleaned what I can and all seems ok. And thing is I did replace the starter relay and still no luck.
How did replacing it work for you? did that fix it or still hunting? I know how frustrating this is, believe me.
Bob
1980 cb750c
Offline w1sa
« Reply #10 on: February 28, 2012, 05:34:04 PM »
You seem to have some interesting things going on here..........
Did you actually connect your test light at the y/r starter solenoid/ relay terminal or......at the y/r at the starter button switch at the handlebar control?
The neutral light is not activated by the starter button activation/power supply............you may have a wiring problem in your switch control/circuit.
Try connecting your test light at the starter solenoid/relay terminal for y/r, depress starter button and your test light should glow (yes/no)...............move the light probe to the g/r terminal and depress the starter button for a few seconds.....does it also light (dimly?) (yes/no)
« Last Edit: February 28, 2012, 05:35:46 PM by w1sa »
Offline Spanner 1
« Reply #11 on: February 28, 2012, 05:44:17 PM »
OP, if when you 'push the start button and the N light comes on ' would indicate a classic example of 30+ yr. old wiring connections being all oxidised... every bike has it. Some fix it, some ride their bikes after many hours of mech. wrenching and 0 hrs. of electrical service/attention. Guess which bikes quit due to ' no power to' ..... ( fill in the blank ) ! A great time to shine-up every bullet and spade connector on your bike along with the fuses/fuseblock and make it solid....... ya want to ride as  carefree as possible, right ?
Oh, and your starter solenoid may be stuck, or more likely has a poor ground or both !
A friend of mine and a member here paid a fortune to have his bike hauled  on a tow truck for 100 miles because his ign. failed due to corrosion on his battery + and - terminal connections... Fix it now or later, your choice  ;) ;)
Offline bobth1019
« Reply #12 on: February 28, 2012, 06:17:50 PM »
Could you tell me what it would indicate if the test light does light at both y/r and g/r? Mine do light up. I've got very similar issues so it would be helpful to know. thank you
1980 cb750c
Offline w1sa
« Reply #13 on: February 28, 2012, 08:16:10 PM »
It tells you that delivered voltage is passing thru the solenoid wiring to your test light......If you can prove continuity from that g/r terminal to the bike's ground/earth system, the problem is almost certainly crudded up/ corroded internals of the solenoid mechanism itself...(especially if the starter motor spins when shorting the two solenoid posts)
Offline adr3naline
  • adr3naline
    • adr3naline
« Reply #14 on: February 28, 2012, 11:40:44 PM »
Wow, this all was a good surprise! I will be doing all these new tests tomorrow and report back. Thanks everyone!
2006 Yamaha Warrior
1982 CB900c
1979 CB650
Offline adr3naline
  • adr3naline
    • adr3naline
« Reply #15 on: February 28, 2012, 11:51:11 PM »
So, some previous owner hacked my wiring harness pretty good. I'm missing a bunch of connectors, and those are now just clamped or even twisted together. Any complete harness would be better... But, would buying another 30+ old harness just keep the bike from reliability?  Are there better options?
2006 Yamaha Warrior
1982 CB900c
1979 CB650
Offline bobth1019
« Reply #16 on: February 29, 2012, 02:25:56 AM »
Thanks...at least in my case the relay/solenoid is brand new as I replaced it thinking it might be the issue.  So although it could be that it would seem less likely than another problem, yes?
1980 cb750c
Offline w1sa
« Reply #17 on: February 29, 2012, 04:08:22 AM »
Yes, from what you say, it seems your problem might be in the ground side.........have you tried the starter with the clutch lever pulled?...............also, you could create a temporary ground from the g/r terminal to the engine/frame, and give it a test try.
As previously stated, the importance of clean secure connections should not be underestimated........a multimeter is also very useful for this type of problem solving.
Offline adr3naline
  • adr3naline
    • adr3naline
« Reply #18 on: February 29, 2012, 11:01:59 AM »
Yes, same situation.
Where does the g/r wire ground too? On the wire diagram it says that the g/r goes to the starter disconnect switch (which I assume is in the starter?).
I currently don't have a headlight on right now, and the 2 green wires in the bundle to the headlight are loose. I have connected them temporarily.
A new wire harness might be in my future. It would make it so much easier to put the bike back together... There's plenty on ebay it looks like!
2006 Yamaha Warrior
1982 CB900c
1979 CB650
« Reply #19 on: February 29, 2012, 11:55:03 AM »
Previous PO might have butchered the harness to correct the 'hot start' issue with 650s.
Offline nwrocker
« Reply #20 on: February 29, 2012, 12:42:53 PM »
You can test the switch with a electrical light pen thingy, by checking the 4-pin harness in the back of the headlight.  The handlebar switch leads to a ground.  It comes into the switch as the yellow/red wire and comes out a different color that plugs into the green/red (neutral safety) ground in the headlight.  Just clip the pen to the engine to ground it and touch the back of the 4-pin connector with the light pen while depressing the switch.  There are four wires that are in that connector.  (black, black/white, yellow/red and the fourth one).  The fourth one is the wire that grounds the handlebar switch.  If your light pen does not light up when you depress the switch, you may have a bad switch or the switch from the wrong year.  I had to rebuild mine because of the same problem.
« Last Edit: February 29, 2012, 10:43:12 PM by nwrocker »
Offline w1sa
« Reply #21 on: February 29, 2012, 03:13:22 PM »
Adr3naline,
Did you do the light test at the starter solenoid relay terminals? If so, what was the result?
The g/r goes to frame ground (from the starter relay) via two paths.......the clutch lever switch and the gearbox neutral select switch............unless one of these is providing a ground, the starter solenoid will not operate.
Offline bobth1019
« Reply #22 on: February 29, 2012, 07:09:47 PM »
You nailed it! I ran a wire off the g/r terminal to the frame, pushed the start button and it turned over just like its supposed to. So I assume it's a matter of just cleaning that connector or replacing?
I really want to thank you for your help, w1sa in particular...I've found the people in this forum to be consistently patient and knowledgeable.  And adr3naline I hope you get your bike running...I'll follow this and see how you do. Good luck.
1980 cb750c
Offline w1sa
« Reply #23 on: February 29, 2012, 08:15:49 PM »
Hey, that's great...............by all means give the connector a careful clean and test its security.......you may find however that the actual ground problem is further down stream....as I said before, that ground path splits. The most conclusive and strait forward test is with a meter (ohm scale)...one probe to g/r and the other to frame, should show about zero ohms on the meter, for a good ground connection............similar with the clutch lever pulled,bike in gear.
Without a meter, bike in neutral, a serviceable neutral light illuminates....that demonstrates that the neutral switch at the gearbox is working ok..if that's your situation you have lost ground connection between the g/r terminal and the junction/join in the line from the neutral light.....(that section (g/r term to junction) also contains a diode/ connection which could be faulty).......alternately, if the neutral light fails to illuminate, the prime cause of the problem could be anywhere from the neutral light  to the gearbox end but most likely at the gearbox end.
« Last Edit: February 29, 2012, 08:31:14 PM by w1sa »
Offline bobth1019
« Reply #24 on: March 01, 2012, 02:56:48 AM »
Got it. Little bit after I wrote my response I realized from what you had said I wasn't done. oh, well...onwards...there is a good neutral light and re "one probe to g/r and the other to frame, should show about zero ohms on the meter, for a good ground connection............similar with the clutch lever pulled,bike in gear." I got zero ohms in both cases. Suggestions? And again, thank you very much for your help.
1980 cb750c
