Author Topic: cafe shown in April 2012 Cycle World  (Read 7131 times)
Offline cwchan
Re: cafe shown in April 2012 Cycle World
« Reply #25 on: March 04, 2012, 02:04:59 pm »
Actually, pound for pound aluminium is stronger than steel - that is, if the same MASS of steel and aluminium were used, aluminium would have more strength.  Of course, aluminium is lighter than steel for the same VOLUME of material used
I believe aluminium is the chosen material because of its inherit properties, stiffness and lightness, not because its repairablility IF damaged
« Reply #26 on: March 04, 2012, 02:14:55 pm »
 There are Heat treaters about 4 hrs drive from here. Had a local manufacturer of frames ran some out of aluminum, and they were all heat-treated. So nmo, I did not try to get a repair re-treated, so I suppose there is a chance it may be hard to find someone to do it.
 An aluminum frame of same dimension as a steel one would weigh a third of the steel one.. so you can add a lot of extra meat, and still weigh a third less, plus have good strength..
 The main problem I see with it is welding after the fact..not re-treated = LESS STRENGTH..
 and there are a few on here that are very concerned  about making a bike handle that have modded dwingarms without re-treating
« Reply #27 on: March 04, 2012, 02:35:32 pm »
Nice aluminum framed race bike...
Nothing wrong with aluminum frames if done right....
Offline jaguar
« Reply #28 on: March 04, 2012, 03:42:19 pm »
I thought that the issue with repairs do Al was that the repair was often stronger then the surrounding material leading to street failures.
Offline BeSeeingYou
« Reply #29 on: March 04, 2012, 04:57:50 pm »
Yeah I think I stated that badly.  I meant that with tubing of the same diameter and wall thickness the steel will be stronger.
Offline Lostboy Steve
« Reply #30 on: March 05, 2012, 07:56:24 am »
Is it just my eyes or does that thing have less rake than my Buell Lightning? At speed that thing has to have death wobble like you've never seen before.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #31 on: March 05, 2012, 02:36:37 pm »
It is built by a well known shop in the UK and raced successfully, its your eye's.... ;D
Its not just the rake that matters, its a combination of rake, trail and triple clamp offset
Offline BeSeeingYou
« Reply #32 on: March 06, 2012, 10:25:13 pm »
Agreed. I think many of these modern sport bikes have a steeper rake around 24 degrees or so but use more offset to get the trail to a manageable number.  But even then it often does not get above 4 inches or 100mm.  Probably why the steering damper is important on these bikes.
« Reply #33 on: March 06, 2012, 10:43:11 pm »
Almost right Steve, less offset = more trail, kinda works backwards..... ;D
Offline BeSeeingYou
« Reply #34 on: March 06, 2012, 11:59:13 pm »
lysdexia...er dyslexia. ;D
« Reply #35 on: March 07, 2012, 01:40:20 am »
A Billy Connely quote, "Old McDonald was dyslexic I E O I E"  :o
