Author Topic: resto/mod project CB400f from Italy  (Read 58211 times)
Offline RickB
    • Pop Magazine
Re: resto/mod project CB400f from Italy
« Reply #125 on: October 25, 2012, 02:25:19 PM »
Depending on whether you have resistive caps and leads, you may have a similar issue that I had. A weak spark.
Have a read through my thread on the issue:
http://forums.sohc4.net/index.php?topic=87505.0
In the end, I determined that it was the different lengths of lead to each spark plug. I know that sounds crazy, but I had brand new Dyna S, Dyna 5ohm coils and leads and caps. After a lot of trial and error, it was the lead length.
Rick.
Offline Mugen_Stumpo
« Reply #126 on: October 26, 2012, 06:11:47 AM »
thanks a lot rick...
i have rebuilt the carb again and still have to try to fire up the bike with them mounted... i'll let you guys know :)
« Reply #127 on: October 26, 2012, 10:18:39 AM »
today i mounted the freshly rebuilt carbs...
the engine still fire up with only 3 cylinders, the one that is not firing is always the 4th cyl
the weird thing is that 1 month ago the problem was that the 2nd cyl wasn't firing... now the 4th is giving problems even with the rebuilt carbs...
damn! :(
Offline RickB
    • Pop Magazine
« Reply #128 on: October 26, 2012, 01:58:56 PM »
Fuel, air, spark. It is one of those issues.
Fuel:
Are your carbs getting fuel? If you open the drain screws in the bowls, do they all have fuel?
Air:
Make sure you don't have a vacuum leak in the rubber manifolds. It's a simple test to do, you'll find plenty of walkthroughs on this forum. If you have a carb sync tool, it couldn't hurt to do that either.
Spark:
Get a multimeter and test your coils. Then leads for resistance. What ignition are you running? Points or electronic?
I would be surprised if it is a problem with your carbs. I would guess an air or spark issue.
Rick.
« Reply #129 on: October 28, 2012, 07:26:11 AM »
finally i made it!
i cut the plug wires like you did Rick and the bike fired up running good on all 4 cylinders
thank you very much!!!!!
Offline Viktor.J
  • Breaking in the forum
« Reply #130 on: October 28, 2012, 07:43:21 AM »
GREAT, congratulations  !
how's she runing on the pods
and
when do you mount the clip ons :D
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
« Reply #131 on: October 28, 2012, 07:58:48 AM »
this is the little #$%*ty video i made this morning
prima accensione a 4
now it's running without any filter, just the rubber staks of the stock airbox, because i want to mount the airbox back for the test...
then change for 85 jets and mount pods
when'll have my license plate, i'll mount the clip-on and everything else, now it's back to 100% stock condition
« Reply #132 on: October 28, 2012, 06:36:30 PM »
Good news
« Reply #133 on: October 29, 2012, 11:11:53 AM »
Hi guys...
i have found this two set of rearsets, i'll try to mount them using a little bracket welded to the frame
the alu one is for a gsx-r, it seems to be shorter than the other on, but the shift lever is pointing the ground, but it looks like that the lever could be self-rotated
the blue one are for a r1, longer mounting plate, but correct shifter bracket
both are made for rear disk, do you think i can use them with the oem drum?
wich one is the best in your opinion?
thanks
thanks
Offline RickB
    • Pop Magazine
« Reply #134 on: October 29, 2012, 04:58:13 PM »
Mugen_Stumpo,
It took me quite a few frustrating hours to get to shortening the spark plug leads so I'm glad it has helped a fellow SOHC4'er!
Rick.
« Reply #135 on: October 30, 2012, 02:31:48 AM »
thanks again Rick you saved my mental sanity too :P
« Reply #136 on: November 13, 2012, 08:45:51 AM »
new shoks and rearsets arrived!
pics on request  :P
Offline Viktor.J
« Reply #137 on: November 13, 2012, 10:47:00 AM »
request :)
haha, which rearsets did you finally choose ?
Honda CB750 K2
« Reply #138 on: November 13, 2012, 01:03:36 PM »
this one... i just need to weld a plate to the frame and start from there...
i think they'll fit nicely
« Reply #139 on: November 29, 2012, 03:20:04 PM »
some little news...
stock triple grinded down to shave risers
fork end plug with built-in spring compression regulation
new warnin-light to be integrated in the triple
« Reply #140 on: November 29, 2012, 07:43:07 PM »
Love the look of the triple, will you polish it?
« Reply #141 on: November 30, 2012, 06:05:56 AM »
still have to grind it a little more but i think i'll polish it then do the holes for the idiot lights
« Reply #142 on: December 06, 2012, 10:19:11 AM »
new stuff :)
« Reply #143 on: January 19, 2013, 03:45:10 AM »
progress of the top triple...
shiny shine 8)
Offline Viktor.J
« Reply #144 on: January 19, 2013, 04:18:50 AM »
Lovely top tree !
And nice gauge and tail light. When will you mount them ?
And have the temperature started to rise in Italy yet ?
Honda CB750 K2
« Reply #145 on: January 19, 2013, 09:56:12 AM »
thanks Vitor...
the bike is still stock because i have to register it as vintage vehicle... i have the appointment for the 25 of january...
then i'll install everything on the bike making it a bit more personal, the cafè way 8)
as today the wheater was really #$%*ty, rain and super cold... i worked a bit...
painted the cafe fenders satin black... the rear one is a stock fender cut the front one is a vtr race replica
Offline hondamatteo
« Reply #146 on: January 19, 2013, 02:15:57 PM »
Would love to see those fork end caps installed. Let me know how they workout when you do. Where did you get them?
'74 CB350F
« Reply #147 on: January 24, 2013, 01:15:24 AM »
some solidwork project i have to complete...
« Reply #148 on: January 26, 2013, 10:47:53 AM »
finally my license plate is arrived...
8) 8) 8)
« Reply #149 on: January 27, 2013, 05:55:57 AM »
some better pics...
