Author Topic: Press In Jets: How much "Press" before they are "in"??!  (Read 531 times)
Offline liPPy
  • 1978 cb750k
« on: February 28, 2012, 12:37:28 PM »
I've just cleaned my carbs (1978k, PD42B) including removing & cleaning the press in slow jets.
How far do the press in jets have to be pressed before they are fully seated?
As it stands, there is a small gap between the shoulder of the jet and the top of the carb housing (see pic below). This is despite some considerable pressing force.
Do I need to close that gap? If so how? Lightly tap with a hammer? I don't want to overdo it...
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
Re: Press In Jets: How much "Press" before they are "in"??!
« Reply #1 on: February 28, 2012, 01:17:37 PM »
Put a dab of some kind of lube like oil or Vaseline on the o-ring, and then push down while twisting till it's fully seated (no gap).  At least that's how I do other press-in type jets; I don't have experience with those carbs...
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: February 28, 2012, 01:45:00 PM »
No o-rings here.. I just fold a rag on top of it and LIGHTLY tap it in, using an upside-down bolt and a ball-peen hammer. Good luck. There should be no gap.
Offline eldar
« Reply #3 on: February 28, 2012, 02:15:09 PM »
I usually tap with the plastic handle of a screwdriver. Just light taps and it goes in.
Offline liPPy
  • 1978 cb750k
« Reply #4 on: February 28, 2012, 02:21:02 PM »
Thanks guys! A short length of hardwood dowel, a couple of gentle taps with the ball peen and all was good.
