Author Topic: My Hondaman 836 motor arrived today - hurrayyyyyy!  (Read 5904 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: February 28, 2012, 02:46:54 PM »
Thought I'd start a project thread for this motor that arrived from Mark today since it's a brand new motor from the ground up. It's going in a ruby red K1 this weekend.
Offline bgfootball67
Re: My Hondaman 836 motor arrived today - hurrayyyyyy!
« Reply #1 on: February 28, 2012, 05:15:42 PM »
Can't wait to see this one!
Columbus VinMoto
Ohio Cafe Racers website - http://www.ohiocaferacers.com
Offline lucky
« Reply #2 on: February 28, 2012, 07:05:29 PM »
Where is it??
« Reply #3 on: February 28, 2012, 08:44:26 PM »
subscribed
Offline 65Ch3v3LL3
« Reply #4 on: February 28, 2012, 09:14:50 PM »
Let's see some pics!
1979 CB650
2011 Harley Road King
2008 Harley V-Rod VRSC DX
2012 Sierra Denali 2500HD
1965 Chevelle Malibu SS
1922 Ford T-Model
« Reply #5 on: February 29, 2012, 07:22:01 AM »
You will love that extra power.When I did my RC836 years ago I was always, for awhile, fishing for another gear in 5th because the power 'felt' like it was still in 4th.
   Is that a 71 engine also?. Thought I read where you went with an early stock cam,correct ? Guys will want all the details !!   Be nice to hear how you set up your carbs also as you get into it more.     Eric
Offline CJK
« Reply #6 on: February 29, 2012, 08:14:21 AM »
Subscribed for sure!
Offline WhyNot2
  • I'm finally an
« Reply #7 on: February 29, 2012, 08:27:24 AM »
Me too...........................^^^^^^^^^^^^^^^^^^^^^
Offline lucky
« Reply #8 on: February 29, 2012, 09:01:23 AM »
Thanks for posting the great photos!!! ;)
Offline Tews19
  • I am no
« Reply #9 on: February 29, 2012, 09:11:15 AM »
subscribed 8)
1970 Honda CB750 survivor.
Offline Damfino
« Reply #10 on: February 29, 2012, 09:32:37 AM »
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline evers
« Reply #11 on: February 29, 2012, 09:40:50 AM »
can you give me the contact details for the engine supplier thanks, evers
93 900 triumph Daytona
83 kz1100st
94 Bonneville
and of course 77 CB750 chop
Offline Coyote13
« Reply #12 on: February 29, 2012, 10:49:42 AM »
Definitely sub'd.
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline mycb750k6
  • Rocketman
« Reply #13 on: February 29, 2012, 12:42:42 PM »
I got it out of the box this morning and am putting shiny side covers on and new cam cover and generally making it purdy. I tried to get some pictures of the intake ports as they are really nice.
I'll try again. It started off as a K0 doner engine that was rusted solid so much of the work needed for this motor would likely not apply to most rebuilds. Here's a list of some of what was done to the motor though.
836 Big Bore job w/big pistons.
Valve job with all new guides and valves
New cylinders from another K0
New K1 cam
All new rocker arms, 2 new shafts.
2 newer cam bearings.
New clutch plate, hub, springs, bolts, hub cup washer
Full oil pump rebuild, polished rotors, skimmed side covers.
New transmission bearings and bearing retainers
New final drive bearing
New cam chain tensioner roller, slipper, bearing set.
Repaired-resculpted 6 fins that were chipped, cracked, or broken & gone.
New spark advance
New points, plate, condensers.
New starter
Primary chain tensioner.
New   primary chains
new rod and crank bearings.
Starter clutch rollers and alternator.
Compression 9.5:1
Basically a new motor.
So I'm planning on putting it in a ruby red K1 this weekend but I'll try to keep this thread current. So it will be a K1 with a late  numbered 104... K0 motor just before the K1 switch at 1044.....
So now I'll have a perfectly good K1 motor from the bike I'll need to find a home for.
I've got to break it in because of the new bottom end but I'll include the carb tuning when I get to it.
I'll get more pictures as I go.
evers, the "supplier" is Hondaman. I believe he has 4 motors to do in the Q but you can order one on his web site I believe.
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
« Reply #15 on: February 29, 2012, 04:47:58 PM »
Sounds like a nice strong running,sensible and reliable street set up.Once the carbs etc are dialed in you will be wearing the grin  ;) Sounds like you may be going with some nice stock HM300's hopefully. If so those things will roar.  Did Mark give an estimate to the HP,I would guess maybe close to 80 possibly. ??   Looking forward to updates also.    Eric
« Reply #16 on: February 29, 2012, 05:08:30 PM »
It will be noticeably stronger but i doubt it will get near 80HP without port work.... ;)
Offline mycb750k6
  • Rocketman
« Reply #17 on: February 29, 2012, 05:46:09 PM »
Yes Mark said  80, maybe low 80s, maybe high 70s -  with the big bore, advance, cam, head work, port work and valve work and quench bands. Ports look really cool too and the combustion chamber I posted on his web site.
« Reply #18 on: February 29, 2012, 05:47:46 PM »
Do you have rebuilt carbs to put on it?
Can you tell we are like a bunch of vultures?!
I would like for him to rebuild one of my motors too.
Offline mycb750k6
  • Rocketman
« Reply #19 on: February 29, 2012, 05:51:42 PM »
Yes I have a couple sets of K1 carbs and new manifold rubbers so I should be fine. Why do you ask? Do you rebuild them?
« Reply #20 on: February 29, 2012, 05:52:50 PM »
Thats more like it.... ;D ;)
« Reply #21 on: February 29, 2012, 06:29:50 PM »
No, I was just curious. I read through your list of upgrades twice and it seemed like carbs was the only thing not mentioned.  Hondaman and Digger rebuild carbs.
Offline evers
« Reply #22 on: March 01, 2012, 09:49:09 AM »
cheers
83 kz1100st
94 Bonneville
Offline CBDee
« Reply #23 on: March 01, 2012, 05:38:06 PM »
MUST... HAVE... MORE... PICTURES!!!!!  ??? ??? :o
Sent from my Old & Busted PC using Myindexfingers
« Reply #24 on: March 01, 2012, 07:40:47 PM »
I agree.
