The SOHC/4 World Tour is in under way.
If your having clearance issues withe cable Dellorto sells a 90 degree elbow for the top of the carb.
Not sure how I missed this thread! I'm in love with your project. I have a hope that some day someone will come across my bike buried in a barn and resurrect it to race again. Subscribed!
Quote from: fastbroshi on February 14, 2013, 04:52:12 PMI'd imagine the diameter would have to be somewhat bigger given that stock, each cylinder had a 22mm carb bore to breathe through. If it even idled wouldn't it severely limit the top end? There's that other member here with the yellow framed, turboed 550. Pick his brain and see what he's got.Bob3050 has a different sized turbo, the one that came with the ATP kit back in the 70's...I think he has the bendix zenith carb that came with the kit..not sure what size they were, but they were modified with bigger jets, and a larger float bowl.
Quote from: MondayLSR on February 24, 2013, 06:00:54 PMNot sure how I missed this thread! I'm in love with your project. I have a hope that some day someone will come across my bike buried in a barn and resurrect it to race again. Subscribed!Thank you for the compliment Matt! I have been keeping track of your Bonneville build as well, and am very impressed with your fabrication skills...simply incredible how you built that exhaust manifold from scratch! I look forward to any input you have for my build
Def a no brainer, nice carb! Looks like it needs a soak, do you guys have an ultrasonic cleaner?
That's genious!
I am running a fuel pump at 3lbs of pressureIF I CAN EVER THE THE BIKE BACK DANGjim
Well Jim I was going to check.Guess I know now. Greggo tank and latches ship tomorrow. Bill
I dipped into my box of turbo bits, and I cleaned up a Mikuni 36mm carburetor with a float bowl-fuel pump. The pump bolts onto the side with the bowl, and pumps right into the bowl for when it's on the boost. This carb has a functioning choke too, so it's kind of a no brainer. I wish I could quit my job and be a shop rat...this bike is calling me
Quote from: Greggo on March 23, 2013, 12:37:20 PMI dipped into my box of turbo bits, and I cleaned up a Mikuni 36mm carburetor with a float bowl-fuel pump. The pump bolts onto the side with the bowl, and pumps right into the bowl for when it's on the boost. This carb has a functioning choke too, so it's kind of a no brainer. I wish I could quit my job and be a shop rat...this bike is calling me I believe that's an external accelerator pump, that pumps fuel FROM the float bowl and squirts it into the carburetor throat, via one of those plastic tubes and the upper brass nipple. The pump lever needs to be linked to the throttle somehow. Is there a one-into-two sort of throttle cable in the box??
