Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Took apart my 78 CB750, And was wondering why the head gasket is miss shaped on the combustion o-ring.Is it made this way, or should I be looking out for something?
Quote from: bmikkalson on February 29, 2012, 12:04:39 AMTook apart my 78 CB750, And was wondering why the head gasket is miss shaped on the combustion o-ring.Is it made this way, or should I be looking out for something?It is not called a "fire ring" it is just a head gasket and the shape of it is so that when one of the valves that is very close to the edge of the cylinder wall. So when it is open and then you tighten down the cylinder head the gasket crushes and creeps, then it will not hit the valve. Mostly 1977 and 1978 with the larger valves like the F model also.
