Author Topic: Clutching?  (Read 1215 times)
Clutching?
« on: March 05, 2012, 09:29:01 AM »
Do you clutch for every gear change? I catch myself quite often just going up without touching the clutch.  Like 3 to 4 or 4 to 5.
Just curious:)
Offline scunny
  • don't call me expert
Re: Clutching?
« Reply #1 on: March 05, 2012, 09:36:29 AM »
normally only use clutch to take off and shifting down.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline WhyNot2
  • I'm finally an
Re: Clutching?
« Reply #2 on: March 05, 2012, 10:11:04 AM »
what scunny said, 'cept occasionally downshift w/o it too.
Offline ADW
Re: Clutching?
« Reply #3 on: March 05, 2012, 10:21:28 AM »
Yep, every time. Upshifting and downshifting.
Offline singedebile
Re: Clutching?
« Reply #4 on: March 05, 2012, 10:32:41 AM »
I am curious to hear more about this, I always use my clutch when shifting (though have experimented a few times not doing so)...   so I take it if you are careful you can do this without hurting the bike?
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Re: Clutching?
« Reply #5 on: March 05, 2012, 10:46:14 AM »
My jeep can shift without clutch to once its moving.
Offline I Zombie
Re: Clutching?
« Reply #6 on: March 05, 2012, 11:05:34 AM »
Ah the fun of snycho-mesh gears
78 CB750K
Re: Clutching?
« Reply #7 on: March 05, 2012, 11:42:33 AM »
Er- non-synchromesh gears. These are not synchromesh transmissions. Known as "crash boxes". Also known as "constant mesh" as all gears are turning all the time.
Yes you can shift them without the clutch and at times it feels benign. But you will accelerate the wear on the shift dogs and all points of contact. ITs all a matter of degree. If you fan the clutch and give the trans some relief, the wear will be less. The better you are at meshing engine speed with land speed, the less it will wear.
but wear it will.
Its an overall technique.  There are those who always use the clutch but still do more damage when shifting than many who might not use the clutch.  I hear them decelerating in front of my house to the stop light. Bang, bang, bang.
« Last Edit: March 05, 2012, 11:48:19 AM by MCRider »
Offline CycleRanger
  • No comment about being an
Re: Clutching?
« Reply #8 on: March 05, 2012, 11:49:27 AM »
Yes you can shift them without the clutch and at times it feels benign. But you will accelerate the wear on the shift dogs and all points of contact. It's all a matter of degree. If you fan the clutch and give the trans some relief, the wear will be less. The better you are at meshing engine speed with land speed, the less it will wear.
but wear it will.
Yeah, pretty much THIS!
Offline I Zombie
Re: Clutching?
« Reply #9 on: March 05, 2012, 12:01:46 PM »
damn thought i had that one right, my bad
78 CB750K
Offline Gordon
  • 750K1, 550K2
Re: Clutching?
« Reply #10 on: March 05, 2012, 03:57:50 PM »
Same here.  I like my transmission.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Clutching?
« Reply #11 on: March 05, 2012, 04:03:08 PM »
Been doin' it this way for 60,000 trouble-free miles.  :o
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Gordon
  • 750K1, 550K2
Re: Clutching?
« Reply #12 on: March 05, 2012, 04:11:39 PM »
That makes sense.  I heard the transmission doesn't explode until you hit 60,0001 miles. ;D
On a more serious note:  Have you actually opened up the transmission to inspect the shift dogs?
Re: Clutching?
« Reply #13 on: March 05, 2012, 04:12:44 PM »
I know drivers who hurt gears while clutching ;D
If you know your vehicle, listen to the engine and watch rpms, you can shift smoothly without clutch.  I think the impact on longevity is minimal.
Offline chickenman_26
    • Motorcycle Consumer News
Re: Clutching?
« Reply #14 on: March 05, 2012, 04:22:56 PM »
... I think the impact on longevity is minimal.
Maybe, maybe not. Depends on the skill (and luck) of the rider. But clutchless shifting definitely will increase wear on the gear dogs. When they're worn enough, you'll know it. Classic symptom is popping out of gear and into a false neutral when accelerating hard. At that point, any repair will require a complete engine and transmission strip down and costly gear replacement. If it's that important to someone to not use the clutch, I guess I'm missing something.
Stu
MCN DTF
