Author Topic: CycleX Oil filter adapter problem  (Read 1416 times)
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
« on: March 05, 2012, 04:54:00 PM »
Has anybody else had problems with the oil filter adapter from CycleX. I cannot tighten mine due to fittings for oil cooler hitting engine case. Other problems too, but this one makes it unusable. Ive contacted CycleX but no answer as of yet.
Offline wrenchmuch
« Reply #1 on: March 05, 2012, 05:05:56 PM »
I turned mine so the holes faced down. I used 90 deg npt to -8 adapters to connect to the line. I remember I had to fool around with it for a while to figure it out.
CB750K1
CB750K4
Offline millerza
  • Zach Miller
Re: CycleX Oil filter adapter problem
« Reply #2 on: March 05, 2012, 05:21:19 PM »
you're kidding. I really figured mine was an accident.    Do the lines hang much below the engine?
Offline cbr954
« Reply #3 on: March 05, 2012, 05:34:24 PM »
The fitting on the original Lockhart oil coolers from back in the day face down also.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline wrenchmuch
« Reply #4 on: March 05, 2012, 05:36:24 PM »
I went to the garage sorry it's not on the bike right now.
CB750K1
CB750K4
Offline wrenchmuch
« Reply #5 on: March 05, 2012, 05:43:16 PM »
When it's on the adapter is rotated counter clockwise a bit. I use the cooler in the summer when it gets above 80 deg. I haven't fitted a themosatic valve yet. The fittings are all Russell and the cooler is a small Setrab unit that bolts to 2 small tabs I welded to the frame. The cooler fits just under the horn.
CB750K1
CB750K4
Offline millerza
  • Zach Miller
« Reply #6 on: March 05, 2012, 05:45:49 PM »
aight. I dont like it, but ill try it out.
Offline millerza
  • Zach Miller
« Reply #7 on: March 05, 2012, 05:54:05 PM »
look 100 posts  yay   lol
