Author Topic: '78k. and the widest tire it can wear.  (Read 1816 times)
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« on: March 05, 2012, 07:38:00 PM »
Hey all, what few posts I could find using the crap-tastic search function didn't really answer my question, so I ask;
What is the widest 17" rear tire I can run before chain rub becomes an issue. I want wider meat for more grip on my K, but I have the rim broken down for powder coating and can't take measurements for myself. I was thinking of going 160/60/17 on a 3.5 rim, after piecing together 3 or 4 posts on the subject, but am still not sure if that will work. This is with the stock swingarm and hub. I don't run a chainguard, and clearancing the brake stay is no issue.
Any thoughts? Experiences?
Thanks,
Gonzo
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline eldar
Re: '78k. and the widest tire it can wear.
« Reply #1 on: March 05, 2012, 07:50:36 PM »
More grip how? I suppose going straight but then even with a 130 tire, that is not an issue.
A wider tire can hamper cornering performance, negating any gain from a larger tire.
A 160 should fit fine but I think you might be disappointed. A 130 fits quite fine and looks pretty good too.
Offline Gonzowerke
« Reply #2 on: March 05, 2012, 08:23:32 PM »
More grip how?
When cornering.
Once I find out/decide what wider size to go with on the rear, I can then select a wider front to match. Right now, the 100/90/19 is equal to the 3.5-19, and the 120/90/17 is equal to the 4.5-17. On the rear, a 130 is 1/2 an inch wider, a 140 is 1 inch wider, a 150 is 1 and a 1/2 inches wider, so maybe the 160 is a bad choice. If I go 140/90/17 on the rear, and 120/90/19 on the front, I should be okay handling-wise. With a 130, I should be allright with the 110/90/19 I currently have on the front.
 My question now is, will the 140 clear the chain?
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: March 05, 2012, 08:36:32 PM »
A wider tire will decrease the size of the contact patch, not increase it, because the tire will be pinched more than a correct size tire forcing the tread into a tighter arc.
Offline Gonzowerke
« Reply #4 on: March 05, 2012, 08:51:58 PM »
Oops. I didn't mention that I am going to use the proper width rim for the size I choose. Mea Culpa! ;D
Offline eldar
« Reply #5 on: March 06, 2012, 05:12:59 AM »
A 140 fits fine then, if you are using a wider rim. I have about 3/8th inch between the tire and swing arm on each side with my 130.
Offline KB02
« Reply #6 on: March 06, 2012, 06:02:46 AM »
Yes.
I am running a 160/60/17 on the stock Swingarm in my K8. A 140 will fit just fine. As far as chain guard clearance, I don't know. I'm not running a chain guard because it will not fit with the 160.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Gonzowerke
« Reply #7 on: March 06, 2012, 08:52:11 AM »
Yes.
I don't run a guard either, it was the first thing to go when I got it. What size rim are you using on the 160? Did you go wider at the front too? What size there?
(EDIT) Nevermind, I just waded through all 19 pages of your build thread and answered my own questions!
Thanks,
Gonzo
« Last Edit: March 06, 2012, 09:15:18 AM by Gonzowerke »
« Reply #8 on: March 06, 2012, 04:37:10 PM »
A 160 will fit but you will need a 4.5 inch rear rim for the tyre to work properly, some manufacturers say that a 4.25 rim will do but it will be better on a 4.5. Clearance issues can be fixed a number of ways, the K7-8 rear sprocket carrier and gearbox output shaft are 10mm wider than earlier K models and 10 mm offset sprockets can be bought for front and back from CycleX.
Offline KB02
« Reply #9 on: March 07, 2012, 04:00:00 AM »
Thanks,
Gonzo
Yeah, and that pic reminds me of what a good idea it was to ditch that dash set-up. :)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
