Author Topic: LED turn signal question  (Read 1801 times)
Offline srbakker
  • Spam & Eggs
« on: March 05, 2012, 11:26:02 PM »
For those of you using front led signals, where did you mount your resistors?  These things can get a bit warm and I don't really want to put them in the headlight bucket.  Any thoughts or pics greatly appreciated.
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
bollingball
Re: LED turn signal question
« Reply #1 on: March 06, 2012, 05:34:30 AM »
I thought you could get bulbs with built in resistors look here to find out. Or do you do it through the flasher. Maybe some one who has done it will chime in. So here is a bump. I do know in the past it was a pain in the a.. But not so much now with the newer bulbs.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fled_prods.htm
                                    Ken
Offline I Zombie
« Reply #2 on: March 06, 2012, 12:03:25 PM »
find a 2 prong flasher made for leds, they'll work both reg & led bulbs.
78 CB750K
Offline srbakker
  • Spam & Eggs
« Reply #3 on: March 06, 2012, 12:48:23 PM »
Perhaps I am an idjit (this would not be the first time) but I have an electronic flasher for the rear blinkers.  I was under the impression that the front blinkers do not have separate flasher relay?  Maybe I just need to review my wiring diagram again.  :P
1975 CB750 K5
2007 Triumph Tiger
bollingball
« Reply #4 on: March 06, 2012, 12:56:16 PM »
One flasher works all four.
Offline I Zombie
« Reply #5 on: March 06, 2012, 12:58:09 PM »
Not all electronic flashers work for LEDs, you need a LED specific one. 1 flasher does all the signals.
« Last Edit: March 06, 2012, 01:21:17 PM by I Zombie »
78 CB750K
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #6 on: March 06, 2012, 12:58:46 PM »
No, they are wired through the same flasher unless you wiring harness has been unnecessarily molested.
I had to run standard bulbs in the back even though I replaced the stock flasher on my bike with the LED flasher from superbrightleds.com .
When I attempted to run LEDS on the front and back it did not present enough of a load to trip the flashers.
That's OK because the rears are only used when I flip the turn signal so not a whole lot of wattage is wasted. The LEDS are in the front where they are used as running lights and turn signals so I can save a few watts.
Offline srbakker
  • Spam & Eggs
« Reply #7 on: March 06, 2012, 01:39:44 PM »
Ah ha.  I have reviewed the wiring and see where I missed the connection.  Thanks for all your help, it's been invaluable!
1975 CB750 K5
2007 Triumph Tiger
Offline Bailgang
  • Scott
  • Indiana
« Reply #8 on: March 06, 2012, 02:43:59 PM »
I've got LED's on my 550 using nothing more than a 2 prong electronic flasher I picked up at the local auto parts store and it works like a charm.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
