Author Topic: head bolt specs for CB650?  (Read 2163 times)
mplastow
« on: May 31, 2006, 10:36:30 AM »
I'm chasing down oil leaks after a rebuild on my '81 CB650.   I stripped at least 2 bolt holes when reassembling the 22 bolts holding down the head cover.   I suspect I may have inserted some bolts in the wrong holes, in spite of my best attempts to tag them by number from the tightening sequence in the Haynes manual.
Does anyone know where I can find the correct bolt lengths for each of the 22 head cover bolts?
Offline bma300
Re: head bolt specs for CB650?
« Reply #1 on: May 31, 2006, 01:20:31 PM »
If I remember correctly the 2 longer bolts go into the 2 center holes.  If looking at the cylinder head with the exhaust side facing you it would be the back center 2.  If you need to get a helicoil kit it should be the M-8 1.25 size.
Offline cb650
« Reply #2 on: May 31, 2006, 03:19:54 PM »
Dont forget the sealing washers.
                   Terry
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #3 on: May 31, 2006, 07:14:51 PM »
Attached pdf is an exploded view with the bolt sizes indicated.  Shazam.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
mplastow
« Reply #4 on: June 01, 2006, 06:02:56 PM »
csendker: you are a hero in my book.  Thanks for your help with that pdf!!!
Thank you all for your help.  At least now I can make sure I have the right bolt for the right hole before I start with the helicoil process.  I'll post again once I get it fixed.  May be awhile; the rebuild I just did took 30 hours.
« Last Edit: June 01, 2006, 06:05:32 PM by mplastow »
Offline csendker
« Reply #5 on: June 01, 2006, 06:44:08 PM »
You can find the rest of the exploded diagrams here --> http://www.crotchrocket.com/fiche_select.asp
Just drill down to your bike.  I printed them all out for my bikes and have 2 nice binders handy at all times.
You can also go here --> http://www.honda4fun.com/libretti/libretti.html for a downloadable the Owner's manual and other stuff.
mplastow
« Reply #6 on: June 09, 2006, 10:56:36 AM »
Helicoiled bolthole #22 without removing cylinder head from bike- yipee!!
Bike is running great at first push of the button---and no oil leaks!!! (for now.)
