Author Topic: Accessing the gear box  (Read 1262 times)
Offline Canucklehead
« on: March 06, 2012, 06:03:37 PM »
I just bought an old CB750 K5 which has a gear box issue (won't go into second and has a whooshing noise from the gearbox) is it possible to get into the gearbox from underneath; that is take the engine out of the frame, have it upside down (drain the oil etc before this obviously) and get into the gear box without upsetting the upper end? The top end is in good shape and doesn't have any issues. Can I do it this way or am I stuck doing a full tear down?
Offline Pecantree
Re: Accessing the gear box
« Reply #1 on: March 06, 2012, 06:20:35 PM »
Shh! Don't upset the upper end! >:(
Yes you can.
CycleX sells a undercut tranny you can swap out or buy one on ebay.
Check your shift forks too.
Good luck :)
Offline cbr954
« Reply #2 on: March 06, 2012, 06:32:24 PM »
Yes with the engine out of the frame you can split the cases without doing anything to the top end.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
« Reply #3 on: March 06, 2012, 07:11:38 PM »
Thanks for the replies, I guess I'll turn it upside down and attack from the rear  ;)
« Reply #4 on: March 06, 2012, 07:29:27 PM »
Before you pull the motor and split the cases, you may want to pull the shifter cover off the left side of the motor, and check out the shift linkage and the end of the shift drum. ;)
« Reply #5 on: March 06, 2012, 08:57:01 PM »
Thanks Scotty, that was the first part of the plan, I'm just trying to think ahead a bit.  :)
« Reply #6 on: March 06, 2012, 09:04:15 PM »
Do the easy stuff first! ;) (just where in BC are you? You may be in close proximity to a real expert or two..)
« Reply #7 on: March 06, 2012, 10:07:04 PM »
I'm in Merritt, fairly close to Kelowna and Kamloops. Next to some of the best motorbike roads in BC  :)
« Reply #8 on: March 07, 2012, 08:23:17 PM »
Kelowna, huh? Seems I've heard of that place somewhere... ;)
« Reply #9 on: March 18, 2012, 05:01:01 PM »
Looks like my problem may be a worn stopper shift drum, it shows quite a lot of wear and doesn't lock into the gear detents well possible due to the wear creating a little less tension on the spring? I'll replace this first and see what happens. When I moved the drum and wiggled the rear tires the gears all moved nicely, no catch for now. Hopefully this is a cheap fix.
Canucklehead.
