Author Topic: Pipe color  (Read 938 times)
Offline DaveInTexas
  • 1970 CB750
Pipe color
« on: May 31, 2006, 02:28:32 PM »
I noticed my new to me bike has 3 nicely bronzed pipes and one that is still silver (#4).
I wish I'd noticed what they were like when I bought it last month (only as a troubleshooting thing).  Maybe the silver one was a recent replacement.
One does not heat up quite as much as the others at idle, but its not the chrome one, its one of the bronz-ey ones (#3).
Is it possible to have the carbs set too lean or the timing too advanced in such a way that the engine makes too much heat and melts valves or bronzes exhaust pipes, etc if I am running only low speed and short rides in town, always below 4000rpm?
I will get it tuned up but I'd reallly like to ride a few miles to find all the bugs at once - as long as I'm not hurting it with too much heat.
When I pulled the plugs last they were all sort of fouled, not showing signs of heat stress at all.
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: Pipe color
« Reply #1 on: May 31, 2006, 08:01:29 PM »
The 4-4 exhausts are notorious for rotting out as they don't heat up like a 4-2 or 4-1, thus condensation, rust, etc.  This particularly happens when you do a bunch of short hops, not allowing the pipes to come to full temp and evaporate the condensation.  And yes, individual carb set-up can impact the exhaust temperature.  Too lean and you'll run hot, cooking all sorts of stuff like your valves; that is in addition to the exhaust.  My timing was off, and I noticed it when my 1-4 pipes were running noticeably colder than the 2-3 pipes.  Of course, it was only running on 2 cylinders, so there were other obvious pointers that something was amiss.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
