Author Topic: dyna S ignition bracket mod -elongating holes  (Read 694 times)
Offline judder
« on: March 09, 2012, 11:54:08 AM »
I'm installing a Dyna S in my CB 750K4 and can't rotate the bracket enough to get the spark at full advance. I've been on the phone for about 30 minutes waiting for Dyna support so I decided to ask here. I apologize if this has been discussed before but I did a quick search and found nothing.
I can't get the spark at full advance as per the Dyna instructions so I was thinking about elongating the holes to get the spark where it needs to be. Anybody else do this or am I doing something wrong?
Thanks
Jud
1974 CB750 K4 cafe project bike
1990 Harley Davidson FXSTS
orange550
Re: dyna S ignition bracket mod -elongating holes
« Reply #1 on: March 09, 2012, 12:12:48 PM »
Ok before you elongate the holes, make sure you are twisting the advance fully while setting the timing. I read the instructions a zillon times and had the same issue, then realized what the instructions actually meant. It's a bit tricky to twist and hold the advancer at the same time as setting the timing, but once I figured this out, I had lots of room on the slots.
Offline judder
« Reply #2 on: March 09, 2012, 12:43:25 PM »
Yep, I got her timed by doing exactly what you said. I knew that I was doing something wrong, plus I can't read and understand anything.
Thanks for your reply, now I have other problems cylinder 1 and 2 are not firing, plenty of spark but no explosion.
orange550
« Reply #3 on: March 09, 2012, 01:10:46 PM »
Not sure on the 750 ( I assume that's the bike) but some of the carb sets have a fuel line to carbs 1 & 2 and another to 3 & 4; my 550 for example.
The issue you are describing could be a fuel line issue to 1 & 2.
Also on the timing... you set to the advance mark, no?
« Last Edit: March 09, 2012, 01:14:51 PM by orange550 »
Offline CycleRanger
  • No comment about being an
« Reply #4 on: March 09, 2012, 01:11:55 PM »
Also you can adjust the pickups independent of the backing plate.
I used a multimeter to static time it then a strobe light to tweak in the 1-4 and 2-3 pickups.
Offline judder
« Reply #5 on: March 09, 2012, 01:34:37 PM »
I took the float bowls off and they are getting fuel so I sprayed some WD-40 in the carbs when she was running and she burnt it so I've got carb issues.
I need to go get some carb cleaner and play with the carbs again. I hope I don't have to take the rack out again.
Jud
