Author Topic: are carb boots different for different cylinders  (Read 1262 times)
Offline Scott
  • 72 CB750
« on: March 10, 2012, 03:25:32 PM »
Hello
I have a CB750 1972 just about to put the carbs back on using new boots from carb to cylinder head.
The 4 boots supplied are all stamped #2 on one side #3 on the other.
I was not sent any #1 and #4 boots.
Question is are the boots for #1 and #4 cylinder different than the boots for #2 and #3 cylinder
At the moment it seems that the boots wont line up with the carbs or am I just being soft and need to try harder
Thanks
Scott
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: are carb boots different for different cylinders
« Reply #1 on: March 10, 2012, 03:53:35 PM »
Yes, Number one cylinder uses the boot with the #1 facing up, number four uses the same one, but with #4 facing up. The boots for two and three work the same way.
...................Paul
Offline Irukandji
« Reply #2 on: March 10, 2012, 06:49:18 PM »
Scott..........
I have a 73,
The 2/3 boots are at a different angle
You cant flip them over to make them fit the 1/4 because the opening
is smaller on the other end. I dont think Rotating them will help either
16212-300-030 = 2/3
16211-300-030 = 1/4
« Last Edit: March 10, 2012, 07:05:10 PM by Irukandji »
750k3
Offline Scott
  • 72 CB750
« Reply #3 on: March 10, 2012, 10:23:08 PM »
thanks heaps mate
At least I know why I'm finding it hard to get the carbies back on.
But now I will have to order 4 boots to suit #1 and #4 cylinders to make up 2 full sets.
One set for this bike and then I will have to buy another bike so the other set doesn't go to waste
Scott
Offline 05c50
  • 05c50
« Reply #4 on: March 11, 2012, 05:27:50 AM »
Scott
I like your logic.
...........Paul
