Author Topic: Jet question 550  (Read 1021 times)
Offline messeduptriple
Jet question 550
« on: March 10, 2012, 10:32:01 PM »
I got some new 120 and put one in... Seems a bit not as tight as the old ones... Not sure if this is a stupid question but will it stay tight if I install them and place the carbs back in?? I will have to flip this over. The jet seems pretty snugg but I'm just worried it will pop out.  Should it b fine?
Sent from my PC36100 using Tapatalk
Re: Jet question 550
« Reply #1 on: March 10, 2012, 10:33:09 PM »
« Reply #2 on: March 11, 2012, 12:37:49 AM »
that leaf spring retains it,,,,,against the inside of the float bowl,,,you dont need to remove the carbs to change the jets,,with some dexterity you can wrangle the bowls off and back on in situ.
« Last Edit: March 11, 2012, 12:40:04 AM by dave500 »
Re: Re: Jet question 550
« Reply #3 on: March 11, 2012, 08:11:33 AM »
...........oh......... That seems like it would be kinda hard to do.
Offline Deltarider
« Reply #4 on: March 11, 2012, 12:01:16 PM »
On the contrary, it's not difficult at all. I can do it blindfolded.
CB500K2-ED Excel black
« Reply #5 on: March 11, 2012, 12:11:47 PM »
It IS if your fingers look mostly like toes or thumbs.
Sent from my IMac using manual dexterity.
« Reply #6 on: March 11, 2012, 01:14:56 PM »
I will have to try that next time! I thought that you needed to pull out the carbs everytime u change jets and stuff.
« Reply #7 on: March 12, 2012, 12:04:50 AM »
replace those little phillips(jis)with little allens,then make a short little key/ which fits them when on the bike.
Offline Bailgang
  • Scott
  • Indiana
« Reply #8 on: March 12, 2012, 01:40:22 AM »
+1 on that. I use a short stubby phillips screw driver with 1/2 to 2/3 of its handle cut off.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
