Author Topic: Got a couple of questions  (Read 1079 times)
Offline sayntdownfall
« on: March 10, 2012, 11:12:26 PM »
Ok question #1 I am looking to set my 75' 750F with kick only (no electric start) it will still run a battery can I still have electronic ignition timing if so could someone point me in the direction of a decent set up?
Question #2 Other than Honda OEM bearings are there any other sites or places that sell Main and Rod Bearings?
Question #3 Are things such as the breather vent necessary (the black plastic canister mounted under the battery box)
Question #4 Will earlier cb750 tanks mount on the 75 F model frame?
Question #5 I currently have the wiring diagram from the Haynes manual for the cb750 models but I have heard from a few sources that these manuals leave a lot of valuable information out, does anyone have a good (and clear) 75' F model wiring diagram?
Thanks in advance for any help
Re: Got a couple of questions
« Reply #1 on: March 11, 2012, 12:34:45 AM »
question #1 yes.
Offline Eydugstr
« Reply #2 on: March 11, 2012, 03:20:06 AM »
Welcome to the forum, sayntdownfall.
1) Yes.  Would recommend either Pamco or Hondaman's transistor box.  Haven't had a problem with my Dyna setup, but some others would disagree, and have had mixed experiences with customer support.  Pamco Pete and Hondaman post regularly on the forum.
http://forums.sohc4.net/index.php?topic=83840.0
http://forums.sohc4.net/index.php?topic=15948.0
4) Don't think so.  The length of the tank & where it meets up with the seat would be an issue.
