Support the site. Your contributions keep this site running.
Are you going to build the exhaust for that reverse head?
Sure was. Distributor was from some kind of Fiat. Ran through a sleeve welded onto the valve cover and keyed directly into the camshaft. Worked perfectly but I got too paranoid about the bike falling over.
Quote from: bwaller on February 17, 2013, 05:38:28 PMAre you going to build the exhaust for that reverse head? The harder part will be the 180-degree tach cable! Good ram-air approach!
1975 Honda CB750F
Rear brake, cant stop good on pavement, will probably put 17 with roadrace raintire on tomorrow.. Racing saturday, and sunday. Might pull motor out of it to put in a street bike.will finally get aircleaners on it this wekend.
