Author Topic: Exhaust Repair/compatablility  (Read 799 times)
Offline MILO
« on: March 11, 2012, 01:33:45 AM »
Howdy,
I've come across a set of 1971 CB500 4 into 4 exhausts. I'm building a bit of a custom bike, but I love the 4 into 4 look.
Would these fit my 1975 CB550?
They also have a small hole on the bottom of each lower pipe. Are they able to be repaired? I'm not sure as the metal is quite thin...
-Liam
Offline MoMo
  • Ride like you're invisible
Re: Exhaust Repair/compatablility
« Reply #1 on: March 11, 2012, 04:11:40 AM »
Liam,  not sure about fitment but it seems the pipes should work. The small hole at the bottom of each pipe- you're not referring to the drain hole Honda put in each pipe are you?...Larry
