Author Topic: Exhaust header bolt removal  (Read 2319 times)
Offline Douglas.birnbaum
  • Doug B.
« on: March 11, 2012, 01:32:38 PM »
Does any one have tips for removing the exhaust head bolts from the head?
Cheers and thanks
'76 CB 750A
Offline Johnie
Re: Exhaust header bolt removal
« Reply #1 on: March 11, 2012, 01:44:42 PM »
Welcome to the board Doug. Which bike you talking about here? If it is the 750 I soak it with some PB Blaster or Liquid Wrench and use a impact driver to remove the bolts. On mine with the OEM pipes I have philips flat head holding my header spigots on there. Just take your time you certainly do not want to round those things out. When you get a chance post a pic of your ride. One thing you will notice here is we like pics!!! Again, welcome...there are a ton of guys here that just enjoy keeping these bikes on the road and helping each other out with advise and parts. Let us know how you come out.
« Last Edit: March 11, 2012, 01:47:55 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
  • Doug B.
« Reply #2 on: March 13, 2012, 01:49:34 PM »
Johnie,
  Thanks for the reply, I have a 76 Hondamatic that I'm rebuilding into a Cafe. The exhaust pipe bolts are the old ones that have duel threads on both ends. A friend suggested some heat and then work them out. But it's anyone's game at this point I'm still open to suggestions.
'76 CB 750A
Offline Johnie
« Reply #3 on: March 13, 2012, 02:19:54 PM »
Before heat try the Liquid Wrench, penetrating oil or PB Blaster is what a lot of guys here like. Take your time and let it work overnight. Then gently turn the bolts with a 6 point socket. Don't force it. Last resort use the heat if needed. I would hate to see you have to drill them out.
Oshkosh, WI  USA
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #4 on: March 23, 2012, 07:54:07 AM »
Those are referred to as studs. Unless you really need to remove them, your best bet is to leave them in and clean them with a small wire brush attached to a Dremel tool. To get them out, run two 8 mm nuts onto the threads, and tighten the nuts together. Then use an open end wrench on the inner nut to back the stud out - the outer nut to tighten. Use slowly increasing pressure - don't jerk or pound on the wrench. Once you get the stud to turn a bit, apply penetrating oil as you work the stud back and forth. It'll eventually move more easily and come out without damaging either the stud or head.
Stu
« Last Edit: March 23, 2012, 07:56:12 AM by chickenman_26 »
MCN DTF
