Author Topic: cb750k4 Where to get the 8 orings that are used on fuel feeds for carbs?  (Read 2075 times)
Offline 1974cb550k
I disassembled my carbs and want to replace the 8 (4per inlet) o=rings that are on the 2 fuel inlets. The prob is that the fiche lists them in the carb kit and not individually, also it does not give a size or part # for just the o=ring it only lists it as a kit. I just bought 4 carb kits but they do not include these o-rings (keyster). Has anyone run into this before? Do you guys normally replace them on a full rebuild? Thanx
Offline Bodi
Each Honda carb gasket kit includes enough of these for one tee connection. With four gasket kits you have a set left over.
Someone here had bought a minimum order of the necessary o-ring, I don't recall who. They were available at a pretty low price - compared to Honda gasket sets, anyway.
Offline MasterChief750
  • Detonation
why not grab a universal oring set from harbor freight. the nitrile ones. im sure there has to be an oring that will fit. someone correct me if i am wrong
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline 1974cb550k
 Not worth it to guess with a harbor freight universal o-ring kit. Maybe for something less critical. I'll spend the $ if i have to on 2 oem kits but I have never run across this where Honda does not list a number or size for a o-ring.
Hinomaru
When Honda did publish the o-ring part number and size, it was: 16173-044-004 / size: 7.8 x 1.9
Offline 1974cb550k
Thank you sir. I found them at http://www.oringsandmore.com/servlet/the-2174/Metric-Viton-Orings-8/Detail . I also found a previous post and apparently none of the herbor freight o-rings will work. Furthermore Honda man stated he uses the 8 x 2mm oring for this application. $10 shipped for 10 Viton orings. Problem solved thanx again
Offline 1974cb550k
Offline h2yamyk
Newbie here.  Kawie H2 guy that's restoring a '74 750K. I just ordered these o-rings....how'd they work?!  Thanks!
Offline h2yamyk
PS  Thanks for the link direct to the product page on that oring site.  Super convenient!
bollingball
The Viton are the better ones for this crap gas today also
Ken
I used those two, metric set from hf is a good deal on orings. But orings from plumbing at lowes work well too.  No leak for 4 000 miles so far.
Offline mono
  • Definitely no
+1 to that.  i got the Harbor Frieght kit in the blue plastic box, and found O-rings that replaced them just fine.  there's plenty in the kit, too!  :)
