Author Topic: Painting fork uppers  (Read 1513 times)
Offline CafeWild34
« on: March 13, 2012, 07:18:01 PM »
Hello everybody
I have my forks off for rebuilding and the part of the forks that are under the fork ears are pretty rusted. I already bought different fork ears that won't cover up all the rust. So my question is can I paint this area or do I just get the rust cleaned off as best as possible and leave it like that. Thanks
Offline KJ790
Re: Painting fork uppers
« Reply #1 on: March 14, 2012, 04:16:53 AM »
You can't paint it, that part needs to be smooth and unpainted for the fork seals to slide over. Sounds like you need to have the rust removed and have them polished and rechromed.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: March 14, 2012, 04:31:32 AM »
You could always disassemble the forks and slip the seals over the bottom.
Offline KJ790
« Reply #3 on: March 14, 2012, 05:32:32 AM »
Oops, I thought he meant the area that the fork seals rubbed on. The area between the triple clamps might be able to be painted, but you will probably have trouble assembling them if you aren't careful.
  • 1977 CB550F2
« Reply #4 on: March 14, 2012, 05:46:34 AM »
I had mine painted for years before I could afford new(straight) tubes. :)
Offline grcamna2
« Reply #5 on: March 14, 2012, 07:09:28 AM »
It probably wouldn't hurt to put on a nice light even 2 coat;1 coat primer & one top coat...after you've assembled the forks after rebuild w/ new seals installed.
I would plan on getting another set of tubes eventually.
Offline CafeWild34
« Reply #6 on: March 14, 2012, 01:41:11 PM »
Awesome sounds good I will try a light painting and see how it turns out. I will get some new ones when I get the cash. Thanks
Offline Really?
« Reply #7 on: March 14, 2012, 01:43:10 PM »
They are about $150 a pair at CycleX
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline CafeWild34
« Reply #8 on: March 14, 2012, 02:06:37 PM »
Actually I just took the Emmy cloth to it and it cleaned up pretty good besides ones spot which I might be able to cover up. I do have another question though. In the manual it shows the damper being almost the same length as the fork tube but when I got mine out it is not even half the length of the tube. Am I looking at the manual wrong or do I have the wrong forks for a 550? I gotta go to the laptop to post the pic real quick.
Offline CafeWild34
« Reply #9 on: March 14, 2012, 02:13:31 PM »
Here is the pic of the tube and the damper. Also the fork bottoms have mounting spots for calipers on both of them. I thught that was weird considering it is only a single disc brake but i didnt know if they were all like that. So are these 550 forks or some other?
  • 1977 CB550F2
« Reply #10 on: March 14, 2012, 02:35:50 PM »
That looks fine to me. Yes they do have the extra caliper mount...tho mine doesn't. Someone must have changed it.
Mind you I cant really remember what the originals look like. I had to get the only fork tubes available to me, cut, drill and mix and match.
« Last Edit: March 14, 2012, 02:38:24 PM by LesterPiglet »
Offline grcamna2
« Reply #11 on: April 01, 2012, 02:05:49 PM »
those are CB550 forks.
