Author Topic: Removing Shock Covers CB550  (Read 3758 times)
Offline Pain
  • Female
  • 1976 CB550F (2)
« on: March 14, 2012, 08:19:15 PM »
Can you take the chrome covers off the CB550 rear shocks and still use them? Or are they an integral part of the shock?
Thanks,
Pain
i live for my dream, and a pocketful of gold...
Offline Bailgang
  • Scott
  • Indiana
Re: Removing Shock Covers CB550
« Reply #1 on: March 15, 2012, 02:17:41 PM »
Yes but it's a pain without the correct tools and with out those tools it will probably take you and someone else to give you a hand. With the shock off and setting upright on the floor, with a really strong grip grab that chrome spring cover and put all your weight into it pushing it down. This will compress the spring and release the retainer that's wedged at the top between the cover and the top of the shock absorber. I can't remember if the retainer on mine is a 1 piece "C" type wedge or a 2 piece wedge but this is where having someone else to give you a hand becomes useful because they can pull the retainer out while your hands are busy gripping the cover with all your weight pushing down. You don't have to compress the spring completely, just enough to release that retainer and remember to grip only the cover when putting your weight into it other wise you'll compress the shock piston with it and unable to release the retainer. I'm horrible at explaining things but hopefully you'll get the idea.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Johnie
« Reply #2 on: March 15, 2012, 02:25:08 PM »
My son and I have done a number of them by hand. A mechanics pic for the guy getting the retainers out and some good leather gloves for the guy doing the compressing helps. Make sure the shock adjuster setting is at the lowest.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Pain
  • Female
  • 1976 CB550F (2)
« Reply #3 on: March 15, 2012, 07:16:32 PM »
ok. but can you put it back together without the cover on?
Offline Johnie
« Reply #4 on: March 16, 2012, 04:28:27 AM »
Never tried it without the cover. I do not think it would work as the retainers are held in place by the edge of the shaft end and the edge of the cover.
Oshkosh, WI  USA
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
« Reply #5 on: March 16, 2012, 05:35:30 AM »
You could probably either trim the cover so that you are only using the top most portion, though that may be flimsy.  You could also check local hardware stores for a beveled washer with similar dimensions as the top of the spring cover.
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
Offline Bailgang
  • Scott
  • Indiana
« Reply #6 on: March 16, 2012, 03:56:37 PM »
I think you can but I'm not sure. Once you have the cover and spring off, check and see how the retainer fits over the top of the spring.
Scott
71 cb350 twin
77 cb750 F2
Offline Pain
  • Female
  • 1976 CB550F (2)
« Reply #7 on: March 17, 2012, 04:07:13 PM »
someone has to know. i've seen it done before.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #8 on: March 17, 2012, 04:32:04 PM »
It's easy to check int it? Let us know when you do.
Offline tomkimberly
« Reply #9 on: March 17, 2012, 06:47:03 PM »
You can always make one of these.
Offline Roach
« Reply #10 on: March 21, 2012, 06:19:45 AM »
to answer the original question yes you can the chrome casing is just for decoration.
1978 CB550K Cafe Racer
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« Reply #11 on: March 21, 2012, 10:28:54 AM »
I have done it buy putting the shock mount in a vice and
compressing the spring enough to release the split retainer.
                                       Doug
