Author Topic: SS front brake line length/thread size  (Read 1009 times)
Offline flateric
« on: March 15, 2012, 09:21:44 AM »
Hi,
I am restoring a 1977 Cb550k. I have rebuilt the front caliper and removed the stock brake line to replace it with a Stainless steel one. I have removed the auxiliary brake thing in order to go from brake master cylinder straight to brake caliper (also new brake master cylinder with brake switch integrated).
I need a custom brake line made and was wondering what length is recommended as well as the thread size at stock caliper is? My handle bars are almost like stock (European style - between stock and straight bars).
Thank you
Offline LesterPiglet
  • 1977 CB550F2
Re: SS front brake line length/thread size
« Reply #1 on: March 15, 2012, 10:08:34 AM »
I know the length of mine with Euro bars tho it does have a brake switch in there. Top is 11" bottom is 21". Hope this helps.
« Reply #2 on: March 15, 2012, 11:30:16 AM »
Talk to Shaun - Slingshot cycles. He makes brake hoses for CBs.
The thread should be M10x1.25
Offline flateric
« Reply #3 on: March 15, 2012, 01:33:43 PM »
Thanks for your replies... I contacted Slingshot cycles and hopefully get a solution soon...
« Last Edit: March 15, 2012, 01:51:41 PM by flateric »
