Author Topic: CB400F charging system  (Read 2336 times)
Offline ttr400
    • ttr400 Projects and Billet parts.
« on: March 15, 2012, 11:39:14 PM »
Just wondering does the CB550 Charging system put out more power than the CB400F system.
The reason I ask is would the 550 stator be an upgrade over the 400F system.
Thanks Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Re: CB400F charging system
« Reply #1 on: March 16, 2012, 12:43:36 AM »
i was comparing a 350 stator against a 500/550 one a while ago and i think they are the same,they test the same,fit into each others cover the same but the lead is different thats all,heres the thread.
http://forums.sohc4.net/index.php?topic=98316.msg1095928#msg1095928
Offline ttr400
« Reply #2 on: March 16, 2012, 01:00:01 AM »
Thanks Dave.  I must have missed that thread.
But yes also discovered that the 550 stator fits into the 400/350F cover.
Just wondering if it puts out more power..
Kevin
www.ttr400.com
« Reply #3 on: March 16, 2012, 01:02:31 AM »
honda man was interested in the stators swapability also,he might have done some research?,the rotor is different.
« Reply #4 on: March 16, 2012, 01:28:01 AM »
The published specs for the two systems (400 and 550) are the same. 150W @ 5000RPM
Some published specs for the CB500 have it making 200 Watts.  I rather think that is a misprint.  But, I haven't tested that one for output.
Offline faux fiddy
  • bike in a box
« Reply #5 on: March 16, 2012, 03:02:59 AM »
200 watts  at redline? !
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline camelman
  • Man... Myth... Legend
« Reply #6 on: March 16, 2012, 09:28:14 AM »
Lloyd, do you have specs for the 350f?
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #7 on: March 16, 2012, 12:19:47 PM »
I've not personally tested for maximum alternator output.  I'm just pleased when they recharge the battery and run the lights.   ;D
Here are the specs, I'm able to glean from my many manuals:
Honda CB500/550 Shop manual, Chapter 6, A.C. Generator Specification.
Type and Manufacturer - LD110-01, Hitachi
Output  - 150W
Battery voltage - 12V
Polarity - Neg Ground
Charging speed - 1000 to 9000 RPM
Weight - 3kg - (6.6 lbs)
Later on:
In Chapter 13 - Technical Data of the CB500
Alternator - Three Phase A.C. 12V - 0.2 KW/5000 RPM
In Chapter 13 - Technical Data of the CB550
Alternator - Three Phase A.C. 12V - 0.11 KW/2000 RPM
Clymer Honda Service • Repair Handbook 350-550cc Fours • 1972 - 1974  Sixth printing November, 1975
CB350F - A.C. generator 5000 RPM/0.156KW
CB500 - Alternator - Three phase A.C. 12V - 0.2KW/5000 RPM
CB550 - Alternator - Three phase A.C. 12V - 0.11KW/2000 RPM
Clymer Honda Service • Repair • Maintenance 350-550cc Fours • 1972 - 1978  Sixth Edition Ninth printing October, 1990
CB400 - Alternator 5000 RPM/0.156KW
