Author Topic: Rewelding my own cam...  (Read 1351 times)
Offline Lumbee
    • My pics...
« on: March 16, 2012, 07:06:53 AM »
Hey guys, I have an old triumph engine I am restoring (http://trw500.blogspot.com/) And have significant wear on the cam. I am not up for paying megacam for a regrind and am thinking of adding some filler to the lobes and grinding them back to spec. Specifically I am wondering about the appropriate composite metal I should as filler. Would standard ER70/80 tig rod be sufficient, or is there something more appropriate out there?
"I'm not a welder, but I play one on HondaChopper.com"
Offline LesterPiglet
  • 1977 CB550F2
Re: Rewelding my own cam...
« Reply #1 on: March 16, 2012, 07:08:22 AM »
Wouldn't the cam need hardened or something after welding?
Offline Artf0rm
« Reply #2 on: March 16, 2012, 08:02:53 AM »
that doesn't sound like it would last very long.
Offline grcamna2
« Reply #3 on: March 16, 2012, 12:30:16 PM »
Lumbee,
     Check out Delta Camshaft in Tacoma, WA. deltacam.com 800-562-5500 They do great work at a Very reasonable price  ;)  :)
Offline lucky
« Reply #4 on: March 19, 2012, 06:54:26 PM »
That would not be hard enough. Use Stellite hard facing electrodes, and remove the flux for TIG welding. The TIG process will keep the heat down.
Then just do the grinding and polishing.
« Last Edit: March 19, 2012, 06:58:08 PM by lucky »
Offline Lumbee
    • My pics...
« Reply #5 on: March 20, 2012, 08:18:41 AM »
Thanx for all the replies.
Unless I find a used cam that is in better condition that mine is, I am planning on doing this myself. My plan is to make a  key that has the correct profile for the lobes, and use that as a gauge. The damage is not much prolly less than 1/16" grooves.
Keep in mind this bike only puts out about 15hp, so its no beast.
