Author Topic: Can I clean my UNI air filter with the K&N clean/oil kit?  (Read 4065 times)
Offline singedebile
« on: March 16, 2012, 03:36:19 pm »
I didnt look at the package and wasnt thinking, i realize now there may be some big differences between the way the UNI filters are made and the K&N ones... or maybe not
So what do you think? I would have bought a UNI kit but they didnt have it at the cycle shop... do I need to return this?
,thanks for the help!
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline LesterPiglet
  • 1977 CB550F2
Re: Can I clean my UNI air filter with the K&N clean/oil kit?
« Reply #1 on: March 16, 2012, 03:45:12 pm »
If it's the same basic design as a K&N I would say yes.
Offline singedebile
« Reply #2 on: March 16, 2012, 03:51:30 pm »
I havnt yet fondled a K&N filter, and they look a bit different then most foam filters so I wasnt sure. Thank you
Offline KB02
« Reply #3 on: March 16, 2012, 06:53:40 pm »
Be VERY careful an read the instructions for both the Uni filters and the cleaner kit. Not all filters are created equal and the cleaning kit for one style filter will actually destroy another.
Typically, gauze type filters, like the K&N, will all use a similar cleaner/oil and work just fine. The same goes for foam filters. BUT, don't use foam oil and cleaners on gauze filters and vise versa.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #4 on: March 16, 2012, 07:24:55 pm »
TT I think has good Uni foam experience. The only ones I have seen sadly in 750's are usually quite degraded,disinigrated and no longer functioning. Have pics if you have the stomach.  :)
Offline Patrick
« Reply #5 on: March 16, 2012, 08:16:32 pm »
It really doesn't matter if the cleaner will work. Both K&N and UNI (I have both on bikes now) have to be oiled to work correctly. The filter element on the filters is very different and the oil you use on them is not the same. They are different things.
And if you are going to run and unoiled UNI, save yourself some time and trouble and just wrap a towel around the intake on your carbs.
Patrick
« Last Edit: March 16, 2012, 08:24:00 pm by Patrick »
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline singedebile
« Reply #6 on: March 16, 2012, 11:58:20 pm »
*removed/deleted/whatever*
« Last Edit: March 17, 2012, 06:50:39 am by singedebile »
