Author Topic: brandEn's K4  (Read 179729 times)
Offline nvr2old
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #175 on: March 10, 2013, 06:38:36 PM »
The 750 is looking real nice brandEn.  You've made good progress.  I really like the seat, too.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline brandEn
« Reply #176 on: March 10, 2013, 06:52:22 PM »
Thanks Uncle D!
Hey Larry! Hope all is well.
Offline UncleD
« Reply #177 on: March 10, 2013, 07:13:48 PM »
No problem. I also have a K4 so I'm really curious to see what you will do with this one. Your other bike is awesome and inspirational!
Offline brandEn
« Reply #178 on: March 15, 2013, 09:00:15 PM »
Got some more work done today. I worked on the rear fender and mounted a Lucas style tail light and some of those cheap EMGO indicators. I like the way everything is coming together. I am considering coating the fender gloss black. I think it would make the chrome on the tail really stand out. I also mounted some Euro bars.
I need to repair these threads on the rear hub. Bummer.
Modified speedo drive for dual discs
I got new stainless pistons from this dude dgs38
Started working on my gauges. I filled the tach damper with new 10K fluid and rolled the odometer back to zero. I need to find some face plates that I like and rattle can the bezels. The chrome on the back plates is shot so I need to figure something out because I would like to keep them chrome.
« Last Edit: March 15, 2013, 09:04:15 PM by brandEn »
« Reply #179 on: March 15, 2013, 10:39:54 PM »
All the other bling and you aren't polishing up the caliper arm?
I spent some time on the polisher tonight on a couple CB550 caliper arms. Going to have to sand on one of them some (and repeat) as it didn't come up as nice. Need to use the dremel buff as I didn't have any of the cone buffs to get in around the raised portion for the adjustment screw...
David
Offline brandEn
« Reply #180 on: March 15, 2013, 10:42:45 PM »
Actually its about 65% polished... Just got to spend another 15-20 minutes with them on the wheel. I see what you mean though the pictures don't look polished at all. I hate polishing... ;D
Offline brandEn
« Reply #181 on: March 15, 2013, 10:44:32 PM »
Here is a better picture
« Reply #182 on: March 15, 2013, 10:53:56 PM »
Send them over, I like polishing and sanding, its therapeutic...but I'm a little nuts some say.  Since I'm unemployed right now, some spare time I have, motivation...depends.
Yours should polish up nicely, the parting line on the bottom will eat your wheels or tug the part when it catches.  A little time with an orbital sander on that seam would blend it nicely. Or careful file and sandpaper work.
David
Offline brandEn
« Reply #184 on: March 16, 2013, 08:08:46 PM »
David
Thanks David. I can handle it but that's a generous offer!
« Reply #185 on: March 16, 2013, 08:47:01 PM »
Nice work on the Speedo drive plate.  Bike is coming along nicely.  When we dry out here you'll probably be done and ready to ride.   We'll have to meet for a ride and a pulled pork sammich at Paseos in Fremont.
Offline brandEn
« Reply #186 on: March 16, 2013, 08:48:27 PM »
Dude I have been there a long time ago. Killer mex for sure! This thing won't be ready to ride for months. But TAO is ready to roll!
Offline SOHC Digger
  • I'm not an
« Reply #187 on: March 16, 2013, 10:01:39 PM »
Looking great already!  Gonna be another tight bike for sure!!!
Offline brandEn
« Reply #188 on: March 16, 2013, 10:08:14 PM »
Thanks Digger! Also thanks for the carb help...
Offline edhaeuser
« Reply #189 on: March 16, 2013, 10:51:37 PM »
[quote author=brandEn link=topic=103818.msg1346791#msg1346791 date=13
S
[/quote]
I got mine from this guy at ebay
http://myworld.ebay.com/retro-motorcycles/
Good quality, but I don't know if he has later faces for yours.
Another place is cb750 guages.com.  I think they are from the Netherlands. Free shipping on eBay though it might take a while.
Ed
Offline brandEn
« Reply #190 on: March 16, 2013, 10:58:14 PM »
Thanks Ed!
The CB750gauges is Lecram, a member here. He has the best looking gauge parts as far as I can tell.
Offline edhaeuser
« Reply #191 on: March 17, 2013, 05:19:33 AM »
Thanks Ed!
Yes, they sure look nice!  I think mine may have been one of his resold by and American seller.  I could be mistaken though.
Ed
« Reply #192 on: March 17, 2013, 11:45:03 PM »
BrandEn,
So, careful on the prep...
http://flic.kr/s/aHsjEnMYAT
David
Offline mark52
  • 1975 cb750 k5
« Reply #193 on: March 18, 2013, 07:04:55 AM »
Hey branden, really nice project build. Have a question for you if you don't mind? You note that you will need to fix the threads on your rear hub, how are you going to go about that. I have two hubs that look about the same (maybe a little worst) that your and would really like to repair, or get them repair,so that they don't become nothing more than door stops. In the tips section one of the members suggested using a tap to clean the threads up but it doesn't seem like that is working for me.  Any help or insight would be great.  Once again I am enjoying watching your build. Thanks
Mark
Mark
Offline brandEn
« Reply #194 on: March 18, 2013, 08:19:01 AM »
BrandEn,
David
Those look fantastic!
Offline brandEn
« Reply #195 on: March 18, 2013, 08:24:41 AM »
Mark
Thanks Mark,
Well I just officially repaired the thread in my rear hub. I had a cheap tap from Harbor Freight and ground about 1/4" off the tip to eliminate the taper. That way I could use the whole length of the tap to bottom out on the hub threads. Just dragged it slowly and carefully along the threads filing away the damage. It took me about 1/2 an hour. I took my time and would clean the threads with a wire brush and try screwing in the retainer getting a bit further each time. Its important to make sure the threads are very clean each time you try because the damaged threads will gall VERY easily.
Offline brandEn
« Reply #196 on: March 18, 2013, 09:08:11 PM »
Built my first wheel. Satisfying accomplishment.
Offline brandEn
« Reply #197 on: March 18, 2013, 09:10:36 PM »
I also got a new rear "trolley" stand for TAO since she lost her spot on the lift. Moving it around in the garage made easy.
« Reply #198 on: March 18, 2013, 09:39:18 PM »
Wheel looks nice, digging that trolley stand for TAO.
Which Avons are you using on TAO, how do you like them and how are they wearing?  What sizes and pressures are you running?
Thanks for the polishing props, it is therapy for now.
David
« Reply #199 on: March 19, 2013, 08:04:58 AM »
Branden,
Can you tell us more about the stand?
