Author Topic: brandEn's K4  (Read 179811 times)
Offline brandEn
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #250 on: April 20, 2013, 06:51:37 PM »
The motor is looking good!
Thanks!
The head is going to be GM satin black. With the silver metallic powdercoated engine covers its really going to look sweet.
Offline brandEn
« Reply #251 on: April 20, 2013, 06:57:02 PM »
So after some confusion, an email, then a reply, and a bit of math I figured out my end gaps. Can't say enough good about Mikes machine work. The bores are perfect and the end gaps need no filing.
Pistons = 2.56"
Wiseco recommends .0045" per inch for the top ring which equals .011" gap. Mine is spot on out of the box.
Wiseco recommends .0055" per inch for the 2nd ring which equals .014" gap. Mine is spot on out of the box.
Thanks Mike for making things so easy.
Offline edhaeuser
« Reply #252 on: April 20, 2013, 10:21:10 PM »
Wow.  Looking really good!
Ed
« Reply #253 on: April 21, 2013, 01:40:31 AM »
That is some bike porn...very nice. David
So I received my head and cylinders from MRieck and they look great. I already have the cylinders painted and took these pictures before I tape up the head for paint. I installed my APE cylinder studs and started checking ring end gap for my Wiseco 836 kit.
Installed the studs like Mike suggests. Small amount of red loctite and not much torque. Mock up the head and jugs and torque down the nuts letting everything set up for 24 hours.
« Reply #254 on: April 21, 2013, 05:37:50 AM »
Looks good Branden. I am very happy #1 chamber cleaned up as well as it did....it was pretty corroded. When using the Loctite make sure it does not "bubble up" when istalling the 2 studs that deliver oil to the top end. It will block the main galley feed holes. You can figure out what happens than and I have seen this occur.  I put the Loctite in the threaded hole (using a toothpick) on those 2 studs to prevent it from riding up the stud threads. I blow air through the oil feed holes in the head at the end to make sure everything is clear
Offline brandEn
« Reply #255 on: April 21, 2013, 09:01:27 AM »
Thanks Mike, I learned that lesson the hard way unfortunately on my F3 build.
Still hurts to think about.
Offline brandEn
« Reply #256 on: April 23, 2013, 12:35:43 AM »
Prepping for paint
Offline brandEn
« Reply #257 on: April 23, 2013, 12:44:34 AM »
Final coat
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #258 on: April 23, 2013, 06:42:17 AM »
Branden
You've got one amazing paint shop too.
What paint are you spraying?
Offline brandEn
« Reply #259 on: April 23, 2013, 07:03:59 AM »
Yea it's pretty good for stuff like this but I wouldn't want to paint a tank in there. It's not enclosed. Anyway my whole engine is shot with VHT engine enamel. Tige has had good success with it so I figured I would give it a go.
Offline Vinhead1957
« Reply #260 on: April 23, 2013, 07:41:28 AM »
Sure is going to be a purty motor!
Offline tweakin
  • tear down
« Reply #261 on: April 23, 2013, 07:43:17 AM »
Damn,  wish I got paid to work on bikes....   Great success with VHT, it's all in the prep and the after bake.
Offline brandEn
« Reply #262 on: April 23, 2013, 08:11:05 AM »
All work was accomplished on my union negotiated break times
« Reply #263 on: April 23, 2013, 08:40:01 AM »
Having Installed Infrared heaters for my shop heating I can see how they would be handy for painting. Even when the air is cold the part will heat up to where you can't even touch it.
Nice job, btw.
Offline brandEn
« Reply #264 on: April 23, 2013, 08:06:42 PM »
Just pulled the top end out of the oven. I am very pleased with the color scheme.
Offline Frankensteins Bride
« Reply #265 on: April 23, 2013, 08:18:49 PM »
Thats a wonderful colour scheme! I like it :)
Working on: 78 Cb750k
Waiting for arrival: 73 Cb750
Frankensteins Wolf
Offline edhaeuser
« Reply #266 on: April 23, 2013, 08:20:03 PM »
Sexy........
« Reply #267 on: April 23, 2013, 08:25:49 PM »
Great looking engine Branden... ;)
Offline brandEn
« Reply #268 on: April 23, 2013, 08:47:57 PM »
Thanks everyone. Unfortunately the engine build will be on hold while I focus my budget on getting my wheels and tires sorted. Gotta have a roller so I can use my lift for my other two bikes.
« Last Edit: April 23, 2013, 08:50:12 PM by brandEn »
« Reply #269 on: April 23, 2013, 10:07:15 PM »
Sweet-looking engine!!
Offline brandEn
« Reply #270 on: April 24, 2013, 05:49:07 AM »
Where is everyone getting their HD head nuts from?
« Reply #271 on: April 24, 2013, 02:27:09 PM »
Rob {Voxonda} has some mate, he's just looking into the cheapest way to ship.... ;)
http://forums.sohc4.net/index.php?topic=118848.msg1367012#new
Scroll to the bottom for latest update.... ;)
Offline iron_worker
« Reply #272 on: April 25, 2013, 07:24:03 AM »
This is where I got my flange nuts:
http://www.dynoman.net/engine/studs.html
IW
Offline Doctor_D
« Reply #273 on: April 25, 2013, 05:07:58 PM »
I got mine from Mike Reick.
Take care,
David
1978 CX500
1971 Norton Commando
Offline brandEn
« Reply #274 on: April 25, 2013, 05:10:43 PM »
Thanks everyone. Voxonda has me covered.
Hey David!
