Author Topic: brandEn's K4  (Read 179276 times)
Offline Godffery
  • Godffery's Garage
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #525 on: September 21, 2013, 08:46:43 PM »
Where did you order that groovy fuse block?
Online RAFster122s
« Reply #526 on: September 21, 2013, 08:53:28 PM »
Fuseblock looks like HondaMan's, are they relays from him? Are they the std ones about an inch cube without the terminals? Or is it a thinner section. Is it a 15A, 20A, or 30A relay?
Offline brandEn
« Reply #527 on: September 21, 2013, 10:03:52 PM »
The fuse block is from Oregon Motorcycle Parts , the same place I got my R/R from. I made a bracket so it would mount to the stock location.
As for the relays they are from Eastern Beaver , and they are 20 amp "micro" relays. They are pretty slick and should handle the load of my headlight and coils just fine. They are a bit smaller than the standard relays you find at the local auto parts store.
Offline Godffery
  • Godffery's Garage
« Reply #528 on: September 23, 2013, 08:59:34 AM »
Thanks man.
I don't see it on his web site so I'll shoot him an email.
Offline brandEn
« Reply #529 on: September 23, 2013, 09:10:49 AM »
Thanks man.
No prob, his website is a bit "clunky" and dated but he is real good with responding to emails.
« Reply #530 on: September 24, 2013, 07:22:04 PM »
Coming along nicely, branden. Bummed we didn't get out for a few laps this summer.
Good thing your not drinking the water down there  :P
I'll knock down this Valhalla red in hopes the rest of your build goes smoothly...
Lata...
Offline brandEn
« Reply #531 on: September 24, 2013, 07:25:52 PM »
Lata...
haha Cheers!
Online RAFster122s
« Reply #532 on: September 24, 2013, 07:58:21 PM »
Just a thought,
the micro relays made by Panasonic 30A are carried by Digikey and they are under $6 and even with shipping they are a good price. The Littlefuse fuse boxes are available frome them as well, they run between $26-35.
Offline brandEn
« Reply #533 on: September 30, 2013, 04:02:16 PM »
Wiring is 99% done and everything works now.  I ran out of bullet connectors and only needed 2! Placed an order just because it's good to have extra on hand.  I had to remove the harness after all that time spent setting it in place. When I hooked up my battery the only thing that worked was NOTHING. So after retracing some wires and following the diagram I got it sorted out and everything works perfect now.
I have turned my attention to carbs now. I am gathering parts needed to use my stock round top carbs and have accumulated most everything to put them together.
Just wondering if my carbs will create any problems if I run them without these boots?
I am also debating on K&N pod filters or my stock modified airbox with a K&N filter installed. I drilled out the back with a hole saw in 3 places.
Comments? Suggestions?
« Last Edit: September 30, 2013, 04:21:23 PM by brandEn »
« Reply #534 on: September 30, 2013, 05:10:41 PM »
The airbox was called a "still-air box". The original design was to let air enter and become still so the carbs could have a clean whiff.  By drilling the holes you reduce the "still..." portion of the design.
Still, I think either would work fine. I can't remember your cc's. IF its stock I'd go with the box.
IF it's 836 or higher, the pods should work fine in my experience. The larger displacement is less susceptible to the cons of the pods.
Anything other than stock air box will render marginally more performance in exchange for marginally more intake noise, and some breathy reactions to sidewinds and rain. I always thought it gave the bike character.
PS: Chuck the boots, just don't play in the sand.   :D
Offline brandEn
« Reply #535 on: September 30, 2013, 05:19:26 PM »
Thanks for the input Ron. My jugs are punched out to 836 with a Wiseco kit. I am still on the fence with the airbox. The K&N pods are what I would prefer to run but want to keep my options open....
boots chucked, no riding in the dunes for this bike.
« Reply #536 on: September 30, 2013, 05:37:10 PM »
Sorry Ron but thats just not so, most pods have no velocity stacks and the Honda induction system was designed to specifically run with the stacks, pods generally pass turbulent air into the ports messing up the induction, i won't go further into it but the airbox, while it is really too small to supply "still" air,  stops the turbulence which is an undesirable factor in the Honda induction design,  Velocity stacks and good quality pods with inbuilt stacks like some K&N's may  give a small improvement in top end performance as thats what the good pods were designed for but on the street the mod Brandon has already done will let the 750 breathe better and thats what counts...
Pods are also effected by cross winds and rain as mentioned.... ;)  Brandon, I'm going to use an airbox on my 1000cc fuel injected engine and air boxes on the 970 and 900 kitted engines... Pods are a compromise not needed on the street, they have become a bit of a fashion statement in recent times, form over function...;)  I should also say that this all relates to the stock type carbs, different carbs have different needs... ;)  All modern road race bikes run stacks and airboxes....
Offline brandEn
« Reply #537 on: September 30, 2013, 05:45:15 PM »
That's a pretty good post Retro. So what do you think of the holes I drilled in the airbox? I just kind of winged it on the mod, not much info out there as far as air box mods go. Seems like it would flow pretty good now.
« Reply #538 on: September 30, 2013, 05:55:14 PM »
That was a common mod back in the day Brandon, it lets in more air so you will need to rejet and possibly move the needles as well. I'm going to do something similar but try and make it more stock looking like cutting a couple of boxes up to get the shroud that covers the stock inlet hole and double the size...Make sense..?   ;D  Bikes looking great...
Offline brandEn
« Reply #539 on: September 30, 2013, 06:20:23 PM »
Got any info on the K&N pod filters with the built in velocity stacks?
« Reply #540 on: September 30, 2013, 06:28:21 PM »
Your holes are bigger than mine! Can't say how much they help but it looks cool  ;D
Pods on the techie 900 with the CR31's but stock holey box on the low tech 1000 which will use my stock carbs, mild porting and 33.5 intakes. Why, because that's all I have left to play with including $$  ;) so I'm thinking it'll run just fine  ::)
Offline brandEn
« Reply #541 on: September 30, 2013, 06:33:47 PM »
Got any pics of your modified box? Just wondering how others are doing it...
« Reply #542 on: September 30, 2013, 07:01:42 PM »
Branden, Hondaman has a page or so, with pics, on airbox mods in his book...
Offline brandEn
« Reply #543 on: September 30, 2013, 08:03:57 PM »
Yea I actually JUST saw that in my copy by accident. It seems Hondaman's book is ALWAYS the last place I look for information only to discover it has something I needed to know! I need to leave it out on my bench or something.
« Reply #544 on: September 30, 2013, 10:00:22 PM »
I'll see what I can do for pics tomorrow.
Offline brandEn
« Reply #545 on: October 05, 2013, 03:28:51 PM »
Wiring done!
Just need to hook up the starter. I am going to leave it disconnected to prevent any accidental blips of the starter button.  I am real happy with the way this wiring has turned out. Glad I added the relays for my coils and headlights .
Offline brandEn
« Reply #546 on: October 05, 2013, 03:30:22 PM »
Figured I would show how I routed my Slingshot Cycles brake lines. I still need to pick up a double banjo bolt and then service and bleed the brakes.
« Last Edit: October 05, 2013, 03:33:31 PM by brandEn »
« Reply #547 on: October 05, 2013, 03:49:11 PM »
It's looking REALLY new Branden. I'll grab the airbox and snap a pic probably tomorrow. Just got home with plans for the evening and it'll take me a bit to get settled back in.
Offline brandEn
« Reply #548 on: October 05, 2013, 03:53:25 PM »
No worries Jerry I am not in any hurry. If its a hassle don't worry about it. I know you probably got more important things to take care of....haha
Thanks for compliment. I am really happy on the way this bike is turning out.
« Last Edit: October 05, 2013, 04:10:45 PM by brandEn »
« Reply #549 on: October 05, 2013, 04:09:47 PM »
Just dug it outta the basement. Can't do the pic now but it's quite different than your's. When did they change? Anyway I have five 5/8" holes. One on each corner and 3 across the back. I'll get a picture.
