Author Topic: brandEn's K4  (Read 180645 times)
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #800 on: September 22, 2014, 02:11:57 PM »
That front fender looks like it belongs there mate, great choice... ;)
Offline brandEn
« Reply #801 on: September 22, 2014, 02:14:43 PM »
Nice! All the positive responses make my day. Truth be told, the CL450 has a 19" front. I thought it was an 18" but later learned different. Still worked out!
« Reply #802 on: September 22, 2014, 02:39:52 PM »
The bike looks amazing.  Is that a Goddfrey twin disc kit?
« Reply #803 on: September 22, 2014, 02:44:11 PM »
Looks GREAT!
Better be careful, you'll run out of stuff to do  ;)
Offline brandEn
« Reply #804 on: September 22, 2014, 02:44:54 PM »
Not really a kit but he did the rotors for me. Top notch work for sure!
Offline brandEn
« Reply #805 on: September 22, 2014, 02:46:10 PM »
Looks GREAT!
HaHa! never!
« Reply #806 on: September 22, 2014, 02:50:58 PM »
Yeah, I could have asked that better.  Did he countersink the disc carrier so you can use the original stock length rotor bolts?
Offline brandEn
« Reply #807 on: September 22, 2014, 02:53:26 PM »
Yup, I just wished I had him mill the backside of the right rotor to fit the speedo drive. That's on my to do list for the winter.
« Reply #808 on: September 22, 2014, 02:55:36 PM »
Yep, he milled the speedo bracket plate to accommodate the reduced space.  Tight fit, but everything seems to work ok on my 550 dual front.
Offline tweakin
  • tear down
« Reply #809 on: September 22, 2014, 06:49:34 PM »
Fender looks great B!  Look forward to getting my K1 and your K4 out for a photo shoot.
« Reply #810 on: September 22, 2014, 07:27:35 PM »
Looks fantastic.
Offline brandEn
« Reply #811 on: September 22, 2014, 10:46:57 PM »
Now your talkin
« Reply #812 on: September 23, 2014, 05:47:38 AM »
Yes it looks great! Just enough balance front and rear to mask the 19' v 18" issue. I searched high and wide for an 18" fender, microfiches and the local salvage yard. Finally came up with a CB350F front fender as an 18". But it's chrome and double braces, wouldn't look as good on your bike.
« Reply #813 on: September 23, 2014, 07:51:09 AM »
Good solution and you didn't have to fab fender mounts.
Offline brandEn
« Reply #814 on: September 23, 2014, 08:17:17 AM »
Yes Ron your help led me to this solution. The problem with the CB350 and 400 fenders is the were to narrow for my wide tire. I stumbled on the CL fenders and bingo!
Offline brandEn
« Reply #815 on: September 23, 2014, 08:19:03 AM »
The best part! I thought I wanted fender mounts. My bike is modified just enough that no mounts or braces actually looks good.
« Reply #816 on: September 23, 2014, 09:08:30 AM »
With a slightly shorter fender, it looks better without the added brackets.  The PC came out clean, too.  It also beats having to invent the wheel if you go with an unmounted fender -- needing new mounts altogether!
Offline brandEn
« Reply #817 on: September 23, 2014, 12:27:46 PM »
So I rebuilt the stock swingarm and got it installed. I think this bike needs the stock one.
« Reply #818 on: September 23, 2014, 12:39:53 PM »
Lookin' good BrandEn!!!  8)
« Reply #819 on: September 23, 2014, 01:48:55 PM »
Those Excel wheels look superb.  I have some high polish ones on my 750.  I was thinking of using the satin finish ones on my 550 IF I rebuild the wheels (my front wheel has some fair pitting).  I have an OEM replacement for it, but was debating on changing it for aluminum.  Part of the struggle to keep it stockish.
Offline Maurice
« Reply #820 on: September 26, 2014, 11:57:09 AM »
Stunning bike and great work!
Would you mind sharing some details on how you bobbed the rear fender?
Thanks!
Offline brandEn
« Reply #821 on: September 27, 2014, 06:57:57 AM »
Thanks!
Thank you!
The rear fender was a PITA but worth it. Basically I just drilled and ground out the welds that hold the mount bracket on. Then I shortened the fender by cutting off about 4-6"  from the forward section because I wanted the rear portion of the fender to have the stock shape and rolled edges. I then just bolted the bracket back onto the fender and had it powdercoated. It turned out pretty good doing it like this but would be a bit more difficult if you wanted to leave it chrome because the powdercoat hides a lot od the imperfections. I love powdercoat!
Offline brandEn
« Reply #822 on: September 25, 2015, 07:09:55 PM »
One of my winter projects is to have my bike repainted. The paint has totally started to blister and peel around the filler neck. Not to mention I have never been satisfied with the stripes. I don't like the color and they are uneven.
Soooo, I am going to buy some all black stripe decals and use those. The real question is should I keep the Subaru World Rally Blue and use all black stripes? I want to keep the bike blue but am thinking of something a little darker. I am open to suggestions on paint color if anybody has something for me to look at.......
Offline Gman
« Reply #823 on: September 25, 2015, 07:54:07 PM »
B,
That blue is great, but I don't think black stripes would do it justice.  B/c the blue is dark enough (esp. if you go darker), I think you need something with some contrast and I don't think the black has that - it would just get lost.   One more comment - the line of the strip leading into the seat doesn't quite sit well with me.  From the side, I think it would flow better if the end of the stripe leading into the seat were curved into towards the center of the tank (from the top), so that it looks like it lines up w/the curve of the seat where it meets the tank.  (Make sense?  To me, it looks like the stripe is 1" below the seat level.)  And, in looking at it, that might be hard to do.  Almost looks like you would have to lower the front edge of the seat, rather than monkeying w/the stripes.  Then that would open another can of worms.   Hmmm...
Disclaimer - I always hesitate to give my opinion, as I don't want to appear as if I'm criticizing, so please don't take it as such.  Your bike(s) are beautiful (mine is in nowhere the same state of polish), so it's more of my musings on what would make a perfect bike perfecter.  :D
Peace,
G
« Last Edit: September 25, 2015, 08:01:55 PM by Gman »
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline tweakin
  • tear down
« Reply #824 on: September 25, 2015, 07:59:07 PM »
I vote to keep it as is with correct stripes this time around.  The silver off the blue pops and looks tits.
