Author Topic: Question on swingarm bolt 76 550  (Read 2912 times)
Offline messeduptriple
« on: March 17, 2012, 10:21:34 AM »
Is this the correct bolt?? Also there's a slight bit of play... Should I have washers inside of it???
Sent from my PC36100 using Tapatalk
Offline Mcwilliams570
Re: Question on swingarm bolt 76 550
« Reply #1 on: March 17, 2012, 10:35:43 AM »
I am pretty sure that is the wrong bolt it looks like it will hit the sprocket nuts etc when they are put on...
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
« Reply #2 on: March 17, 2012, 10:38:43 AM »
The bolt that was in mine when I stripped it down and for all I know it may not be the right one but what was on it..
Matt
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: March 17, 2012, 10:55:12 AM »
That is definitely the wrong one Messed. Matt has the correct one.
« Reply #4 on: March 17, 2012, 11:28:11 AM »
There's no nut with it then??
  • 1977 CB550F2
« Reply #5 on: March 17, 2012, 11:30:30 AM »
The shock is threaded.  Hmm, what shocks are those? They do look a tad wide.
« Reply #6 on: March 17, 2012, 11:32:54 AM »
One more quick question... I bought these progressive 12 shocks... There's a slight bit of play... How can I make them tight???
  • 1977 CB550F2
« Reply #7 on: March 17, 2012, 11:43:47 AM »
Were they sold as CB shocks? Excuse the pics
« Reply #8 on: March 17, 2012, 11:44:41 AM »
I think progressive 12 series
  • 1977 CB550F2
« Reply #9 on: March 17, 2012, 11:49:21 AM »
They are not correct. The bottom mounting on mine is a perfectly snug fit (top pic). Measure the width of the top shock mount, I work in mm. :)
« Last Edit: March 17, 2012, 11:51:43 AM by LesterPiglet »
Re: Re: Question on swingarm bolt 76 550
« Reply #10 on: March 17, 2012, 11:53:47 AM »
could I just measure the width and replace inside of shock with some thick washers to push the shock snug toward the bolt?
  • 1977 CB550F2
« Reply #11 on: March 17, 2012, 11:55:59 AM »
I get 15mm for my top.
  • 1977 CB550F2
« Reply #12 on: March 17, 2012, 11:57:11 AM »
I suppose you could but it may look sh1t.
« Reply #13 on: March 17, 2012, 12:08:51 PM »
I don't know what else to do?
  • 1977 CB550F2
« Reply #14 on: March 17, 2012, 12:14:53 PM »
Well if you can't exchange them you dont have much choice. You will need to do the same to the top.
