Author Topic: What a Day! ... and Question on Carbs  (Read 1778 times)
Offline Imago
  • 1978 CB750F
« on: March 17, 2012, 11:24:15 AM »
On this unseasonably warm day in Saskatchewan I just had to start work on my new (to me) 1978 CB750F.
I got it out of the garage and running great on all 4 cylinders (each exhaust header hot to touch), but it won't idle without stalling unless the choke is pulled pretty much all the way out.
I need to replace the choke cable (which I have - new OEM Honda), change the oil and get a new battery as I was boosting it... off to Canadian tire for the battery... any recomendations on oil?
What first re: the crappy idle... carbs?
I'm thinking the slow jets are plugged... do my symptoms describe this condition, or is there something else I should look for?
If so, is there a link to a carb cleaning thread for bikes with accelerator pumps? I searched, but haven't found anything definitive.
What a day!!!
« Last Edit: March 17, 2012, 11:29:53 AM by Imago »
Re: What a Day! ... and Question on Carbs
« Reply #1 on: March 17, 2012, 11:47:13 AM »
That is my first thought, clogged jets. If you haven't done so, you really should give it the full 3000 mile tune up (plugs, points, condensers, time and valve adj). And change the plug caps too.
Offline Imago
  • 1978 CB750F
« Reply #2 on: March 17, 2012, 01:42:20 PM »
...and another question... is the 3000 mile tuneup information in the shop manual (which I have but for this year jumps from 600 to 3600 miles) or in a dedicated link here somewhere? I've searched, and seen many references to it, but...
Offline harisuluv
« Reply #3 on: March 17, 2012, 02:17:14 PM »
I see the stock airbox on the 78 in the picture, is that still the case?  If you went to pods or have the airbox off it could do the same thing.
Offline Imago
  • 1978 CB750F
« Reply #4 on: March 17, 2012, 02:27:08 PM »
Yes, it's stock. I took the photo this morning right after I got the '78 started.
Unfortunately the yellow '76's engine is stuck. That's my next project starting with the ATF/Acetone de/un/sticker.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #5 on: March 17, 2012, 02:41:06 PM »
Those Henry Abe wheels on the yellow bike?
Offline Imago
  • 1978 CB750F
« Reply #6 on: March 17, 2012, 02:45:40 PM »
Yup, a 19" front and 18" rear. I was happy to find this bike recently in Saskatoon. The PO over-rev'd the engine passing a truck and a valve hit a piston... so I've got a bit of work to do on this one! He said he drove it home and it froze sometime thereafter, but I have yet to open it up to see how bad it really is.
« Last Edit: March 17, 2012, 02:48:50 PM by Imago »
Offline Greggo
  • Somebody's
« Reply #7 on: March 17, 2012, 03:07:22 PM »
Nice.  Of the sets I've seen go for sale on ebay, most went for nearly $1K, and were sold to buyers in Japan.  Great find!
Offline kap384@telus.net
« Reply #8 on: April 23, 2012, 09:24:33 PM »
What a day!!!
Sounds exactly like mine.  Make sure slow jets and pilots are clean.  Check out the video and write-up on this page:
http://forums.sohc4.net/index.php?topic=66779.50
« Last Edit: April 23, 2012, 09:26:28 PM by kap384 »
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
« Reply #9 on: April 23, 2012, 09:26:54 PM »
What a day!!!
Sounds exactly like mine.  Make sure slow jets and pilots are clean.  Check out the video and write-up on this page as I think it's what you're describing:
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1978 Honda XL100
1983 Honda CX650T
1995 Honda VFR750
2015 KTM 200 XC-W
1963 Suzuki T10
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #10 on: April 23, 2012, 09:57:40 PM »
My K5 had been sitting for an extended period of time when I rescued it.  I had the same problem with idle.  Even though I disassembled and cleaned the carbs, tank and low speed jets (e-string) it continued to die on idle.  I must have pulled the bowls and cleaned them and the jets about half a dozen times before they stayed clean.  In retrospect; I believe that my continued problem was the result of sediment that was trapped in the fuel lines from the petcock to the carbs which I failed to clean initially.  I learned on that one....next time I will make sure of the lines as well.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
