Author Topic: K ...lost on rear wheel installation  (Read 6875 times)
Offline messeduptriple
Re: Re: K ...lost on rear wheel installation
« Reply #25 on: March 19, 2012, 07:58:49 AM »
Disconnect the brake rod for a start. And it still looks like you have the rear brake pedal shaft in the wrong orientation.
yes I think a few things are  wrong.. I'm just gonna wait till tmrw and have a guy who has few 750's and knows what he's doing come and show me correctly.
Sent from my PC36100 using Tapatalk
« Reply #26 on: March 19, 2012, 08:00:00 AM »
what do you mean the brake pedal shaft??
Offline LesterPiglet
  • 1977 CB550F2
« Reply #27 on: March 19, 2012, 08:04:16 AM »
The shaft the rod and pedal connect to that goes through the frame. It looks to me if you push the pedal down the rod will push rather than pull.
« Last Edit: March 19, 2012, 08:22:22 AM by LesterPiglet »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #28 on: March 19, 2012, 08:08:09 AM »
If you look at my pic further up the page you will notice that it's a K frame. I bought a new F frame and everything has been transplanted without modification.
I just remembered, I changed swinging arm too but I cant remember seeing any difference between them.
That was some important info to leave out. I don't know about the 500/550, but the 750 F and K models are very different at the rear. One major difference between the 750 F and 750 K is the rear swingarm brake stay mount. With the shock mounts facing up, the 750 F model (disk) brake stay mount point is on TOP of the swingarm, while the 750 K model (drum) brake stay mount point is on the BOTTOM of the swingarm (again with the shock mounts facing up). You may need to use the K swingarm with the K (drum) rear brake.
« Last Edit: March 19, 2012, 08:21:06 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
  • 1977 CB550F2
« Reply #29 on: March 19, 2012, 08:14:07 AM »
My pic up the page is with a K frame and an F swing arm. The K had an open end arm, the F closed.
The pic with the red frame.
« Last Edit: March 19, 2012, 11:08:33 AM by LesterPiglet »
« Reply #30 on: March 19, 2012, 08:19:57 AM »
My bad Lester, I lost track of the original poster there for a moment. And yes, the swingarm in messed post is upside down as noted by budlite.
TAMTF...
Wilbur
Projects:
« Reply #31 on: March 19, 2012, 09:49:58 AM »
Yea I just went out there and pushed on the rear brake... It pushes instead of pulls... So I just flip it around?
« Reply #32 on: March 19, 2012, 11:03:03 AM »
Take the brake pedal off, rotate the brake pedal pivot approx 180 degrees clockwise, reinstall brake pedal.
TAMTF...
Wilbur
Projects:
« Reply #33 on: March 20, 2012, 05:53:32 PM »
I did take the tri mechanism off... I can't loosen the peg bolt and inside bolt at all... Some reason there locked on tight and won't budge..n even had a friend come and try today and he couldn't beleive how tight that was and why it wouldn't loosen... I don't want to snap the bolt in the reatset. Can that setup be switched without pulling the peg out? I'm having it taken in on Thursday for complete wireing... Chain on and the guy said he can fix the brake issue. When I pick it up it will be ready to go.
« Reply #34 on: March 20, 2012, 06:08:21 PM »
Offline lucky
« Reply #35 on: March 20, 2012, 07:19:14 PM »
I painted the washers for the shocks black.. worked out well...this is as far as I got right now
You need to build yourself a work bench bro!!!
« Reply #36 on: March 20, 2012, 08:06:42 PM »
Yea.. that will be my next project!
