Author Topic: Would you use this sprocket?  (Read 2636 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: March 17, 2012, 11:51:00 PM »
I assume I could get the rust off with a wire wheel.. but would it be ok to use?
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: Would you use this sprocket?
« Reply #1 on: March 17, 2012, 11:57:45 PM »
To get you home if you were stranded in the Gobi desert - yes. Otherwise...no. While it may clean up OK - it looks like the teeth are deformed - ie curved..which is the way front sprockets look when they are toast. Not the worst case of sprocket wear - and if fact would be usable..but would cause chain wear. These are cheap to buy new.
Regards
Mark
« Reply #2 on: March 18, 2012, 01:43:45 AM »
that is full on toast
Offline trueblue
« Reply #3 on: March 18, 2012, 01:49:16 AM »
Yep I have to agree it is clagged
1979 CB650Z
« Reply #4 on: March 18, 2012, 01:56:38 AM »
After the apocalypse, yes.  ...With the matching chain, if it still had its rollers.  Not with a new chain, though.
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #5 on: March 18, 2012, 02:00:26 AM »
+1
Look at your bottom photo, as it shows the shagged teeth best. In that photo, see how one side of the tooth has a shallower angle than the other? There's your sign. A good sprocket has the same angle on both sides. I have had ones that looked like ocean waves, they were so bad. As already stated, this sprocket would just accelerate the wear on the new chain, and you wouldn't want to run the old chain that was on this sprocket as it is most likely done too. When chains break, it is a real party-crasher! Either it whips of the sprocket and puts a hole in the case, thereby oiling your rear tire and tossing you down the road, or it wraps up in the rear wheel, locks it, and tosses you down the road. Or both!
I have heard of it just going bye-bye, doing no damage, but not on our bikes.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline trueblue
« Reply #6 on: March 18, 2012, 02:05:41 AM »
My old one on my 650 jumped a couple of teeth one day under hard acceleration, the next day it had a new set of sprockets and chain on it, it warned me it wasn't happy and I'm just glad the warning wasn't a hole in the case and a spit down the road.
1979 CB650Z
« Reply #7 on: March 18, 2012, 09:54:18 AM »
 It looks useable, not the best and not the worst..
Offline 750K
« Reply #8 on: March 18, 2012, 10:39:02 AM »
I'd wire wheel in up and see what it really looks like rust free, if there's lots of tooth wear you'll know right away.
77 Cb750, 78 Kz1000
Offline CycleRanger
  • No comment about being an
« Reply #9 on: March 18, 2012, 10:44:25 AM »
It looks usable, not the best and not the worst..
Usable, for a while, but replace it if it's within your budget.
Offline heffay
« Reply #10 on: March 18, 2012, 10:57:31 AM »
the pictures don't show the angles very well.
first off, don't put it on newsprint, it makes it hard to see the sprocket.
secondly, don't use flash, it causes shadows that seem to add material to the sprocket.
use a clean sheet of paper or cardboard in good ambient light, not direct sunlight, etc.
i agree with 754... it is certainly better than a lot of sprockets i've seen.
a good test is to try to pull the chain away from the sprocket (when the chain/sprockets are properly adjusted on the bike), if it has a lot of movement and doesn't seem to fit snug within each tooth, get a new one.  A bit of play is ok, but it shouldn't be much.
« Reply #11 on: March 18, 2012, 11:05:05 AM »
Only if I had to. ie if it was the only option.
Offline crazypj
  • I'm brill, me
« Reply #12 on: March 18, 2012, 12:51:47 PM »
Yep, I would make a great ninja 'star' with only a little work  ;D
Offline tomkimberly
« Reply #13 on: March 18, 2012, 01:29:29 PM »
Go ahead and use it, eveyone needs to learn that going the cheap route always costs more money than doing it right the first time.
Tom
Offline nancy
« Reply #14 on: March 18, 2012, 01:31:06 PM »
Did u ever see John Cleese in the "Faulty Towers" series over there? One of his famous quips to the oft-beaten waiter - Manuel...who was holding a plate of salad with a bit of debris in it..was "throw it...away". That sprocket has no future...it is debris.
Offline heffay
« Reply #15 on: March 18, 2012, 01:49:12 PM »
i don't advise using it though... why go to the effort of putting it back on the bike?
« Reply #16 on: March 18, 2012, 02:16:22 PM »
 Here is an easy check, clean it and put a nEW pce of chain over a few teeth, then check for radial movement.. ..that will give a better idea. Wear von a front sprocket, is much harder on chain than wear on the rear..
