Author Topic: Velocity Stacks  (Read 4337 times)
Offline wildrum88
Velocity Stacks
« on: March 18, 2012, 02:57:35 PM »
Anyone know where to find some 60mm velocity stacks that won't cost me an arm and a log? Maybe make your own instructions? i was thinking of just going to home depot and checking out their tubing section to find something that might work. thanks!
Offline wildrum88
Re: Velocity Stacks
« Reply #1 on: March 18, 2012, 03:00:24 PM »
these are some that some guy made....badass.
Offline Spades
  • '78 Honda CB750 / '79 CB 650
Re: Velocity Stacks
« Reply #2 on: March 18, 2012, 03:47:00 PM »
http://www.steeldragonperformance.com/products_2.html
Just don't forget to re-jet and balance after you put them on.
'78 CB750K Bobber
'79 CB650 Cafe
Offline wildrum88
Re: Velocity Stacks
« Reply #3 on: March 18, 2012, 05:57:12 PM »
awesome thank you so much. think ill go with the brass? if i didn't have to rejet with the pod filters, do you think ill have to with velocity stacks?
Offline Spades
Re: Velocity Stacks
« Reply #4 on: March 20, 2012, 07:42:47 AM »
Likely yes. Put em on and see what happens .. or at least that is how I operate!  :-*
'78 CB750K Bobber
'79 CB650 Cafe
Offline lone*X
Re: Velocity Stacks
« Reply #5 on: March 20, 2012, 09:57:33 AM »
The pictured stacks appear to be designed for cosmetics only, not function.  The sharp entry edges and no radius of the bell, the intruding flange that the screens are attached to, and the screens themselves, all will disrupt proper air flow.  Those actually look like they would be more restrictive than a stock air box.  I suggest you do some searches on the forum.  There is a comprehensive thread on velocity stack design somewhere that delves into this subject very well.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline wildrum88
Re: Velocity Stacks
« Reply #6 on: March 20, 2012, 08:57:45 PM »
pretty damn good looking cosmetically though!  ;).
I ran around the block today without pods on and the bike seemed to run just fine. how will i know if i need to re-jet?
Offline Dimitri13
  • 1974 CB550K
Re: Velocity Stacks
« Reply #7 on: March 21, 2012, 01:05:19 AM »
What about the DCC stacks? Are they performance-oriented?
Offline lucky
Re: Velocity Stacks
« Reply #8 on: March 21, 2012, 12:29:17 PM »
Jetting with pods or stacks is almost the same . Very little difference.
Depends if the pods have foam over them.
WE would need to know more information about the engine and type of exhaust
System and muffler being used as far as jetting information.
If you give it sudden  throttle and it dies ,or hesitates then you have more work to do,
« Last Edit: March 21, 2012, 12:32:05 PM by lucky »
Offline wildrum88
Re: Velocity Stacks
« Reply #9 on: March 21, 2012, 12:57:06 PM »
well ill tell ya all about it. Its a 1982 cb650 running a mac 4-1 exhaust with open headers, no muffler. The bike seems to like a raped ape (really wanted to try that saying out ;D) with this setup and k&n pods, no hesitation or dying. i believe the main jets are 35 and the pilot is a 125
Offline alacrity
  • Ride, Optimize, Repeat
Re: Velocity Stacks
« Reply #10 on: March 21, 2012, 04:55:28 PM »
Install fresh plugs. Do a plug chop. Read the plugs. Then, if you understand pluge-ese (the language spark plugs speak), do what they tell you to do.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
