Author Topic: Carb Boots  (Read 2273 times)
Offline weltzing
Carb Boots
« on: March 18, 2012, 06:55:22 PM »
Ok so I have a 1980 cb650c with pd carbs and I am wondering what an alternative is for getting new carb boots for my bike instead of the $20+ ones. I think someone said the kawasaki ninja boots would fit and are cheaper, but not sure?....
Thanks
Offline dfoxengr
Re: Carb Boots
« Reply #1 on: March 18, 2012, 07:37:12 PM »
I would like to know too. 81' CB 650 here.
Offline weltzing
Re: Carb Boots
« Reply #2 on: March 19, 2012, 04:42:58 PM »
will a kawasaki ZX900 carb boots work for my cb650?
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
Re: Carb Boots
« Reply #3 on: March 19, 2012, 06:11:13 PM »
I too are looking for boots for my '81 Cb650C. Right now they are soaking in power steering stop leak fluid. I did a set for my CB550 and they became soft after a few weeks of soaking. You might try this method until you can locate new ones. I know they are hard to find at a good price.
                                            Doug
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Carb Boots
« Reply #4 on: March 20, 2012, 10:41:09 AM »
New rubber is where it's at. Bite the bullet and get new ones. I did, and I'm glad I did.
Offline weltzing
Re: Carb Boots
« Reply #5 on: March 20, 2012, 07:57:07 PM »
I am going to get new ones, but someone said on a different post on here that the kawasaki ninja 900's boots are identical and you can get 4 of them for the price of one cb650's...just trying to confirm that otherwise here goes $100 down the drain...thank god I only paid $100 for the bike! ;)
Offline phil71
Re: Carb Boots
« Reply #6 on: March 20, 2012, 08:47:31 PM »
how exactly is $80 going 'down the drain' if it makes things right again?
Offline weltzing
Re: Carb Boots
« Reply #7 on: March 21, 2012, 06:19:53 AM »
Technically its not, but if the ninja's would fit and work for $25, then I would save $55
Offline weltzing
Re: Carb Boots
« Reply #8 on: March 21, 2012, 06:21:28 AM »
http://www.partsnmore.com/parts/kawasaki/zx900/?filters[category]=carb&filters[fitting]=custom
Scroll down a little and these are the boots...
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Carb Boots
« Reply #9 on: March 21, 2012, 08:40:05 AM »
Hell - for $25 get 'em and see.
Offline Doggie
Re: Carb Boots
« Reply #10 on: March 21, 2012, 10:19:28 AM »
If you buy them, let me know cause I will buy them too.
dht4343@aol.com.
                                Doug
Offline phil71
Re: Carb Boots
« Reply #11 on: March 21, 2012, 10:35:46 AM »
Is this the bizzaro world? why on earth would you be looking for boots from a totally different bike to fit on a SOHC 650?
Offline weltzing
Re: Carb Boots
« Reply #12 on: March 21, 2012, 11:22:57 AM »
If everything is pretty much the same on them, the measurements and what not, then why not find a cheaper alternative? I cannot find the post I found on here not too long ago, some guy used different boots from a different bike in which I recall it was the ninja 900's boots, and he said they worked great. Being a college kid with a part time job hell I am gonna find the cheaper deal, as long as they work though. Just trying to confirm on here that the ninja 900's indeed work, otherwise I have no other choice to buy the originals.
Offline phil71
Re: Carb Boots
« Reply #13 on: March 21, 2012, 01:31:55 PM »
if you're gonna try something cheap and futile, why don't you just get some rubber hose length and cut it to size?
Offline weltzing
Re: Carb Boots
« Reply #14 on: March 21, 2012, 03:17:50 PM »
futile? actually I've also read on here someone used radiator hose for carb boots and that worked fine too
Offline phil71
Re: Carb Boots
« Reply #15 on: March 21, 2012, 03:30:30 PM »
I can make a fan belt from panty hose, doesn't mean it's a great idea.
Re: Carb Boots
« Reply #16 on: March 21, 2012, 06:50:56 PM »
Getting the panty hose is the best part.  ;D ;D ;D ;D ;D ;D ;D
Offline dfoxengr
Re: Carb Boots
« Reply #17 on: April 04, 2012, 07:12:16 PM »
These condemning comments about someone trying to find a viable alternative to an expensive part are what makes forums bad places to ask questions. Hopefully those posting them know don't understand that yet because posting them and knowing it would really be a shame.
Re: Carb Boots
« Reply #18 on: April 04, 2012, 08:05:10 PM »
Seriously, you may find compatible parts made for another bike. It is known that manufacturers will try use a commodity part produced by a company when they can. It is cheaper and easier to adapt a commodity part to your design than design a unique part and buy small runs of that part.
The trick is to figure out what parts were used between brands. I had a plastic starter button break on an old  Kawi, went to the dealer who had been around forever. I asked if he could get one, he said "sure everybody used them". When it came in it said "Genuine Yamaha". Of course it was the same button as the Kawi.
« Last Edit: April 05, 2012, 06:25:26 AM by BobbyR »
