Author Topic: Recent mods - fender / brake light / bars etc.  (Read 6857 times)
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« on: June 02, 2006, 08:19:12 PM »
Well, I received the new brake light in the mail today, and couldn't resist digging in.
Bent the light bracket to 90 degrees and used the license plate mount to attach to the tool box studs on the bottom of the seat pan.  Had to slightly lengthen the slots on the bracket to mate with the bolts, but only a little.  Spaced it off the seatpan with a single nut on each side.  Left enough stud for the bracket, a washer and another nut.
Working on a new seat for it, and have flush mount signal lights coming which will go on the frame where the grab bar bolts used to go through to the rear fender.  Signals mount with adhesive - will route the wires through the existing holes in the frame.
« Last Edit: June 02, 2006, 08:36:32 PM by tintin »
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Removed rear fender / grab bar and put on new brake light under seat
« Reply #1 on: June 02, 2006, 08:22:55 PM »
More pics - shorter muffler is going on soon - will get it cut down and pipe sized to mate with the stock header/gasket.  The flanged area on the muffler is very close as-is, just a touch small to fit over the gasket.  The pipe will be cut down so the bracket is in line with the rear foot peg mount.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: June 02, 2006, 08:25:30 PM »
These are the drag bars I drilled and installed a week or so ago.  A compromise between stock and clubman.  I'll likely go with clubmans eventually.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: June 02, 2006, 08:27:16 PM »
Current profile - will be much improved with different seat and shorter muffler.
Offline Pirate Gonzo
Re: Recent mods - fender / brake light / bars etc.
« Reply #4 on: June 02, 2006, 11:07:28 PM »
Looks really nice!! Is that a Cat eye Taillight? I like the mounting of it. Are you going to hang the plate off the lower left?
73' CB450T
76' CB500T
76' CB550K
77' CB750K
86' 49cc Spree
78CB750F1
« Reply #5 on: June 03, 2006, 12:21:22 AM »
Looks great - what seat are you going to use?
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #6 on: June 03, 2006, 05:39:09 AM »
Yep - cat eye taillight, straight from Taiwan  :D  License plate will be on a sidemount bracket on the left side of the bike.  It won't be lit up, at least for now.  I'll either add LED licence plate bolts or some other method of lighting it up so the cops don't freak out.
Front fender is going too, along with speedo (replaced with bicycle computer).
The seat I'm working on is another CB550F seat that I'm changing the profile of.  Will look something like:
http://www.britcycle.com/Products/51312ANortonRacingSeat.htm
Offline Chris Liston
« Reply #7 on: June 03, 2006, 06:52:00 AM »
Looks great.  Please let me know where you found those blinker lights.  very nice.
1976 CB550F Cafe in progress
Offline KB02
« Reply #8 on: June 03, 2006, 06:56:19 AM »
Lookin' nice!!! I love that color.
What tires are you running on that?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Offline KCs76Cafe
  • Jackson Creek,NC..Deep in the stix of the TRIAD
« Reply #10 on: June 03, 2006, 07:26:26 AM »
Looking good tintin. I like the look of the cateye.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #11 on: June 03, 2006, 12:05:36 PM »
Looks great !
Any worries about taillight to rear tire "love" over a good bump ??
upperlake04
« Reply #12 on: June 03, 2006, 12:39:38 PM »
looking good tintin, the new seat will set it all off nicely.   Nice also to see the friendly gesture to the south of 49ers, I understand today we begin a kinder, gentler SOHC/4..  YES!! ;D
« Last Edit: June 03, 2006, 12:43:10 PM by upperlake04 »
glendaler
« Reply #13 on: June 03, 2006, 12:47:38 PM »
that's a great looking bike, thats exactly what i want to do with my bike, let us know how the turn signals go. thats a really good idea.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #14 on: June 04, 2006, 03:53:12 PM »
Here's the license plate bracket - made it today.
http://www.sohc4.us/forums/index.php?topic=10440.0
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #15 on: June 05, 2006, 07:39:44 PM »
Looks great !
Well, if I hit such a bump that my rear shocks compress the distance between the tire and the light, losing my light will be the last thing I'm worried about  :o  I'm not sure if the wheel would even travel that far - what is the travel on a set of rear shocks anyhow?
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #16 on: June 22, 2006, 05:14:58 PM »
Added a muffler that's been following me around from house to house for the last 6-7 years.  Chopped the pipe down and it slid onto the 550 header perfectly.  Much more aggressive sound, 1/2 the size and 1/3 the weight of the stock bazooka and actually noticed more power  ;D
Had to remove the centre stand without having the stopper on the original muffler to hold it away from the chain.  Only solution I see is to add something to the left rear footpeg bracket to hold it down, or just live without.
I left the pin in for the centre stand - I figure worst case I could use a floor jack to lift the bike from under the pin with a grooved wood adaptor.
« Last Edit: June 22, 2006, 05:17:42 PM by tintin »
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #17 on: June 22, 2006, 05:20:05 PM »
And this is what a CB750F tank looks like on a 550  ;)
« Reply #18 on: June 22, 2006, 06:29:00 PM »
Looks good.  what year tank is that, and where did you get that seat :)
Jarkko68
« Reply #19 on: June 22, 2006, 06:39:48 PM »
Hi Tintin!Nice bike!What is the sound like with shorter muffler?
Offline Fish
« Reply #20 on: June 22, 2006, 06:51:47 PM »
tintin,
That is an awesome looking bike.  I love the mods, nice work!
Are you selling your old muffler?  Also if you don't need that goofy old orange tank I'll buy it... and your sidecovers don't really match anymore...  ;D Haha
- Chad
(No, I'm serious.  Call me)
3 sticks
« Reply #21 on: June 22, 2006, 06:52:40 PM »
NOW its starting to look like a real cafe. I'm seriously digging the visual effects the new tank and seat give off. I'd like to get a new tank for my 78 550 as the stock one is a bit small for my taste.
and i'm with chris. what years' that tank!?
Offline Orcinus
« Reply #22 on: June 22, 2006, 07:00:28 PM »
Looks like the 77/78 F Tank
Currently '77 CB750F2
Formerly '73 CL-350 Twin, '81 GS-650E, '83 VF-750C Magna (till some sum#$%* stole it)
Offline STLrocker
  • whiskey bent and hell bound
« Reply #23 on: June 23, 2006, 12:21:44 AM »
no need to worry about floor jacks and wooden adapters. i just leave the centerstand and pin off of my bike until i need it. then it only takes a minute to put it in place and slide the pin in to hold it to the frame. you dont have to tighten the bolts or put the springs on. when you are done, take it right back off.
Offline maksuttt
« Reply #24 on: June 23, 2006, 04:45:13 AM »
Nice bike!
Is it possible to make bracket on muffler mounting to stop stand? I have same thing on my bike, if you need picture i can make it on weekend.
Do you ride it?
CB-750F 1975
My gallery is here
My blog is here
