I was wondering if anyone has tried to put the lower fork from a GL1000 on the fork tubes of a CB750k.
do you lose the CB fender, do you keep the CB axle and rim
both are 1978 ...the tubes on the GL are bent so I was thinking about just swapping out the lowers so I can use the dual disk setup that the GL has.
I looked but didn't find a specific reference .... I know people usually change the upper and lower fork.they both have 35mm tubes right? should work? any help/links greatly thankfull.
