Author Topic: Everything Blinks  (Read 2274 times)
Offline Douglas.birnbaum
  • Doug B.
Everything Blinks
« on: March 20, 2012, 02:16:50 PM »
Ok, round two for my 76 Hondamatic. Checking the wiring, I now am faced with everything blinking when I hit the signals. I'm not sure if its the signal relay or a bad ground. Any Takers? Please help
Doug
New Jersey!
'76 CB 750A
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Everything Blinks
« Reply #1 on: March 20, 2012, 02:45:59 PM »
what do you mean by "everything"
and . . . by blinking - completely dark to bright - or dimming (but not off).
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
  • Doug B.
« Reply #2 on: March 23, 2012, 06:23:08 AM »
Kandrtech,
   Boss, everything dims not goes black. I checked the schematic I have the connections right but I have I no idea. I took off the relay infrustration, blinking stopped but now no signals.
Thanks man
Doug
'76 CB 750A
Offline Johnie
« Reply #3 on: March 23, 2012, 06:47:01 AM »
Had that same issue on a 77CB750K and it was a loose ground.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #4 on: March 23, 2012, 07:36:42 AM »
Kandrtech,
Thanks man
Doug
If I'm reading you correctly, what you're describing is normal, especially if the engine is idling or not running. The lower the battery state of charge, the dimmer the "flashing" items will get.
Stu
MCN DTF
Offline flateric
« Reply #5 on: March 23, 2012, 08:33:27 AM »
If you have LED blinkers all around, you might need to replace the relay also. The stock relay is expecting high resistance compared to what the LEDs have...
Another solution would be to install resistance on each LED blinker to mimic an incandescent bulb's resistance.
This is my 2c... Hope it helps...
Offline Johnie
« Reply #6 on: March 23, 2012, 08:59:58 AM »
I take it he meant all the blinkers blink together. Sort of like emergency flashers. Maybe he will clarify...
Oshkosh, WI  USA
Offline dave the welder
  • dave the welder
« Reply #7 on: March 23, 2012, 05:55:33 PM »
MY 77 did the same thing. found the ground connection under gas tank broke. i repaired the ground and everything is happy
don't buy it build it
