Author Topic: Using Spare Change to Install Stubborn Side Stand Springs  (Read 3800 times)
Offline Rob69
« on: March 21, 2012, 12:22:27 AM »
I don't know if it's been mentioned before, but using pennies or dimes work great for installing stubborn side stand springs. I place one end of the spring in a vise and then insert a coin (I use pennies) between each coil by flexing the spring. Sometimes I can get enough coins inserted to install the spring without a spring tool.  Other times, the spring is expanded enough that it goes on almost effortlessly with the aid of a spring tool.
