Author Topic: where to buy exended fork tubes....  (Read 858 times)
Offline cben750f0
« on: March 21, 2012, 05:26:02 PM »
ok so i searched, and couldnt find an answer, so i will ask here.
my thoughts are that i want to run clipons, but on top of the triple clamp, so if i could find +2" fork tubes, then i could, it would be a lot less hassle with the tank, and the clearance would be better.
if anyone could point me in the right direction that would be awesome
peace
Offline I Zombie
Re: where to buy exended fork tubes....
« Reply #1 on: March 22, 2012, 06:33:08 AM »
Cycle X has a pretty big range of fork tube sizes
78 CB750K
nomad
« Reply #2 on: March 22, 2012, 06:55:49 AM »
Call them to make sure you're getting the right length.  Their -1's are stock length.  You may need their +1's for what you want to do.
Offline Xnavylfr
« Reply #3 on: March 22, 2012, 08:04:46 AM »
You can also get them from  forks by frank @
http://www.frankmain.qpg.com/
Xnavylfr(CHUCK)
« Reply #4 on: March 22, 2012, 12:09:34 PM »
I have pair of loooooong forks. Say 3" over stock or so.  In decent shape from K4 or so.
I can measure it and let you know.
« Last Edit: March 22, 2012, 12:11:18 PM by 70CB750 »
Offline cben750f0
« Reply #5 on: March 22, 2012, 03:19:28 PM »
thanx guys tats awesome, will check out both parties.
regarding +3, it might be a bit too long, i have a set of clipons that i am going to use, i have also made up a washer to go underneath the clipon boss so it clears the top clamp casting.
should be interesting=)
peace
« Reply #6 on: March 23, 2012, 07:21:57 AM »
I measured the assembled fork: 35 3/4" from the wheel axle center to the end of the tube. Didnt have time to measure the tube only yet.
Turns out the other set i have - K3 - is inch shorter than my K0 forks.  Means the long tubes may be just two inches longer than K0.
