Author Topic: Leaky Carbs  (Read 710 times)
Offline wormser
Leaky Carbs
« on: March 21, 2012, 05:48:44 PM »
My float was not closing so I fixed it with a new clip and float needle but during the repair I discovered that the bowls are stripped and one is completely gorilla snotted on there. Someone did a real number on these carb bowls. And of course my bowls are leaking from the seals now. What would you do repair the bowls? Tear em all the way down and rebuild carbs completely? Or just buy a new set of carbs? Note these carbs were kicking a ton of ass before I took them off. Ke-jin Japans...Thanks for responding. Worm
77 CB550F
73 Norton Commando 850
Offline cmonSTART
Re: Leaky Carbs
« Reply #1 on: March 21, 2012, 05:59:47 PM »
Even if you get a new set of carbs off of fleaBay you may still end up having to work on them.  If the bike was running well on the carbs you already have, I would just fix them.
1981 GL1100 Interstate
1978 CB750F Project
