Author Topic: Changing controls  (Read 1586 times)
Offline cwchan
Changing controls
« on: March 22, 2012, 08:49:34 AM »
Hi,
I'm considering swapping my controls for CBR600RR controls.  The colours are the same for the most part.  But i am wondering about the additional positions.  What is the difference between L1 and L2, R1 and R2?  What are possible complications in the swap?  The one i noticed was the horn grounds to the handle bar in the 550.
Offline KB02
Re: Changing controls
« Reply #1 on: March 22, 2012, 06:30:47 PM »
I could be wrong, but that may be for the turn signal buzzer. I put modern controls on my old F1. The stock front turn signals ha a running light and a blinker AND a buzzer. The new switch only handled the turn signals.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #2 on: March 22, 2012, 07:02:44 PM »
I put R6 controls on my K0. It took some effort on the wiring diagram, but I am very happy with it.
Offline lucky
« Reply #3 on: March 22, 2012, 07:11:28 PM »
I also changed controls on my CB750.
All separate now. I like it.
Click ONCE on photo to enlarge .
Offline northwestdrew
« Reply #4 on: March 22, 2012, 07:28:52 PM »
Hey Lucky, like the look, where did you score those controls?
« Reply #5 on: March 22, 2012, 08:00:08 PM »
I was thinking about separating controls like that, but seeing the picture, I am glad I didnt.
Offline cwchan
« Reply #6 on: March 23, 2012, 09:55:22 PM »
Yeah i forgot about the buzzer.  I won't be using it anyhow.  The cbr controls have wiring for the running lights.  I wonder how well this will all integrate with an acewell speedo/tach
« Reply #7 on: March 24, 2012, 03:33:38 AM »
My problem with the R6 was hard wired low beam and you could add high beam to it. Apparently R6 has two headlights.
I took the switch apart and the additional contact was there, manufactures dont bother with developing different switches. I was able to solder in the additional wire and now I have Lo on all the time and switch to Hi optional. Works for me.
Also for the right hand i was able to thread the plastic housing to accept Honda throttle line. My K0 has pull only.
Good luck with your conversion.
