Author Topic: Recognize this ignition?  (Read 2746 times)
Offline Scott S
« on: March 22, 2012, 05:51:35 PM »
 Picked this up from ebay for cheap. Like, $9 cheap. I figure the advance mechanism is worth that.
 It has "TEC" and "Japan" on the pickups. No other markings....well, some numbers on the plate but I think they're Honda numbers.
 What can you tell me about it?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline phil71
Re: Recognize this ignition?
« Reply #1 on: March 22, 2012, 06:13:36 PM »
it's honda.. and it can be from anything... nighthawk, or DOHC 750.. $9 is a good price, but it's useless without the CDI ignition modules, or signal amplifiers. http://www.ebay.com/itm/81-Honda-CB750F-CB750-CDI-ignition-spark-module-/190607573748?pt=Motorcycles_Parts_Accessories&hash=item2c6118c2f4&vxp=mtr#ht_1975wt_984
you will need two of them, and it's very likely that will bring you to about the same price as a brand new dyna.
Which of your bikes do you picture using  it on?
Offline Scott S
« Reply #2 on: March 22, 2012, 06:44:03 PM »
 Well, from the ad: "up for auction is a ignition unit with the advance unit off a 1976 cb550 ".
 I was hoping to use it on my upcoming "sweep the floor" bike, '71 CB500 engine.
'71 CB500 K0
'81 Yamaha XS650
Offline phil71
« Reply #3 on: March 22, 2012, 08:10:47 PM »
the 76 cb 550 still had points.
I recognize that pickup, and like I said, it was on a lot of bikes from around 81 up, but again, you're gonna spend another $100 on the ignitors...  you'll also need to slot them so you can adjust the timing. It's likely that the springs on the advance mechanism are probably close to what you need..
or, for about the same dough, you could just do this>
http://www.motorcycle-superstore.com/1/5/86/27087/14908/PITEM/Dynatek-Self-Contained-Electronic-Ignition-1976-Honda-CB550-Parts.aspx
 done and done.
« Reply #4 on: March 22, 2012, 11:41:50 PM »
it aint off no 550,maybe a misstype,maybe he meant  650?
Offline thrutheframe
« Reply #5 on: March 23, 2012, 12:07:35 AM »
Looks just like my 79 cb650 ignition.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Scott S
« Reply #6 on: March 23, 2012, 03:57:07 AM »
...maybe more if we knew what those numbers were..
 On the back of the plate, in ink: 341020  That "3" might be a "5", so 541020?
 Well, shoot.....I thought I had scored on a cheap points replacement. :(
'71 CB500 K0
'81 Yamaha XS650
« Reply #7 on: March 23, 2012, 05:47:44 AM »
  You may have.  I have the CDI igniters you need, I'll send them to you for $25.00 which covers postage and my beer for about 3 hours.  I'm not sure how to test them but if anyone can tell me how to test them I'd be happy to test them before I ship them.  PM me if you want them.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline trueblue
« Reply #8 on: March 23, 2012, 05:51:29 AM »
Definately looks like a cb650 pick up, surely it would be possible to adapt it to a 550 but you will need the igniters to go with it.
1979 CB650Z
Offline curemode2002
« Reply #9 on: March 23, 2012, 09:13:13 AM »
That is a CB650 for sure I am very familiar with that one. I wonder why though?  ::)
Bikes:
1980 CB650 Sold
2015 Monster 821 Stripe
Offline Scott S
« Reply #10 on: March 23, 2012, 01:53:21 PM »
 What would I do with the ignitors? How, exactly, would I wire them up with a CB550 harness (which I have two of)?
'71 CB500 K0
'81 Yamaha XS650
Offline phil71
« Reply #11 on: March 23, 2012, 01:57:27 PM »
they plug directly into the 6 pin connectors, and you'd give the black wire switched power, then take the yellow and blue wires to their respective coils.
Offline Scott S
« Reply #12 on: March 23, 2012, 06:38:13 PM »
 Into what 6 pin connector? Would the 550 harness have the right plug?
'71 CB500 K0
'81 Yamaha XS650
Online HondaMan
« Reply #13 on: March 23, 2012, 11:26:02 PM »
If you put all this together, keep an eye on the battery voltage and charging situation. The 550 does not have a lot of alternator like the 650 does, and you might find that you will run out of power, like when running the Dyna S ignitions. Use of stock points and coils (or Dyna's 5-ohm coils) will improve on things...
Offline Scott S
« Reply #14 on: March 24, 2012, 04:32:53 AM »
 Eh, sounds like it's not worth the trouble. The ebay seller has agreed to a return/refund, unless somebody here wants to get those ignitors from Thrutheframe and give it a shot.
'71 CB500 K0
'81 Yamaha XS650
