Author Topic: 76 55o carbs  (Read 916 times)
Offline andymum
76 55o carbs
« on: March 23, 2012, 11:04:32 AM »
Hi peeps
as you can see I have made some new panels around back wheel and given her a new paint job what you cant see is it has holographic flakes it it and really bangs in the sun.
right
what other carbs will fit the 76 550 as dont like origionals and would like to change them
all advice welcome
cheers peeps
Re: 76 55o carbs
« Reply #1 on: March 23, 2012, 11:20:29 AM »
Just about anything can be grafted on with enough money, time, and effort.
How much will you pay?
How much time are you willing to put into it?
How much effort are you willing to spend learning about the principles of carb operation?
Have you seen any carbs that you like better than the originals?
What performance goals have you set for the change?  (Higher/Lower?)
Is your primary goal to have it look different while parked, and make some noise when the engine is started?
Offline shizzomynizzo
  • It's 5 o'clock somewhere
Re: 76 55o carbs
« Reply #2 on: March 23, 2012, 12:06:14 PM »
I think TT is trying to say nothing is going to bolt on and make the bike run right without some work.
Some will cost more than others, but ultimately any carb change will cost way more than tuning/cleaning the stocks.
The cb500 will fit yours, same carb bodies, just different jetting and such.
I read something yesterday...believe it was funjimmy, made cr26's fit his cb550. You'll have to search though...I think he had an adapter made so they lined up. ANyway the cr's will cost 700+ alone plus the machine work and your own time.
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline LesterPiglet
  • 1977 CB550F2
Re: 76 55o carbs
« Reply #3 on: March 23, 2012, 01:53:57 PM »
What exactly don't you like about them? They are designed for the bike. It's a lot of work to adapt something else to fit.
