Author Topic: could use a opinion or two  (Read 2263 times)
Offline aberle
« on: March 23, 2012, 01:50:20 PM »
So im rebuilding my top end, I'm at the honing my cylinders part for my new rings. So i hear its pretty easy to just use a ball hone to get the glaze off and get a nice crosshatch but a local motorcycle shop will do it for 15 dollars a cylinder, so what I'm asking is should i do it myself or pay the pretty cheap price for a professional to do it?
Re: could use a opinion or two
« Reply #1 on: March 23, 2012, 02:22:18 PM »
Do you want to ride or learn how the hone cylinders without training?
Offline cmonSTART
« Reply #2 on: March 23, 2012, 03:46:56 PM »
I don't think it's that difficult, but you do need to get a feel for it regarding the speed of the drill and rhythm of motion to produce the nice 45 degree crosshatch angle.  $15 per hole and you don't have to worry about that.  Personally, I would probably try it myself.
1981 GL1100 Interstate
1978 CB750F Project
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: March 23, 2012, 03:52:31 PM »
I'm sure I did it years ago by hand. It doesn't need to be crosshatched, just scuffed to break the glaze. Some fine wet&dry.
Offline MasterChief750
  • Detonation
« Reply #4 on: March 23, 2012, 04:38:31 PM »
i used a dingle berry ball hone. oil it and the bored and get a nice rythm going in and out ;D break the glaze and check your progress often and dont sit in one spot. keep it oiled and you will be fine
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline lucky
« Reply #5 on: March 24, 2012, 06:51:06 AM »
Before you hone the cylinder walls you need to measure the cylinders top and bottom if you have not done so.
The dingleberry or ball hone only takes a couple passes on each cylinder to get them ready for new rings.  Up an down maybe 10 times each.
You do not need to hone them much. Just a up and down movement in the cylinder as the hone is spinning. Make sure the hone is all the way in the cylinder so the top of the cylinder wall edge does not get all rounded off.
« Reply #6 on: March 25, 2012, 06:19:11 AM »
An Autozone or Advanced Auto up there in GR may have a hone that will work on one of their tool loaner programs    ;)
Offline aberle
« Reply #7 on: March 25, 2012, 09:05:09 AM »
What grit should i use  300 -400? And what size hone.
  • 1977 CB550F2
« Reply #8 on: March 25, 2012, 05:32:30 PM »
Sorry I can't help but laugh.
Dingleberry Noun:
    vulgar. A particle of fecal matter attached to the anal hair.
  • Detonation
« Reply #9 on: March 25, 2012, 05:44:31 PM »
 ;D
I AM THE STIG
Sam is THE STIG
Offline aberle
« Reply #10 on: March 26, 2012, 04:46:00 AM »
Go ahead and laugh I'm a hairy dude and having a messy poop and getting one sucks Haha you know you have been in that situation
