Author Topic: How do you drill out "staked" bearing retainers?  (Read 4545 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: March 23, 2012, 04:41:57 PM »
I assume the idea is to remove the material where the thread was intentionally damaged. But how exactly do you do it?
Offline lucky
Re: How do you drill out "staked" bearing retainers?
« Reply #1 on: March 23, 2012, 05:01:03 PM »
No do not do that!!!
Just unscrew the bearing retainer thats all.Period.
You can use a spanner tool if it is not already too wrecked otherwise you will have to use a punch to get it loose.
You can use a spanner from your hand grinder.
Photo below.
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #2 on: March 23, 2012, 05:26:29 PM »
Photo below.
Why not? I believe it is the accepted way. If you do not, then it is a #$%* to unscrew, and you end up with F'd up spanner holes like in the picture.. The trick is to not use a huge bit, but one about the same size as the punch used to stake it, maybe slightly larger. Get it in the hole, and just go down enough to remove the original staking. When all the work is done, you just re-stake it with a center punch in the same location so you don't have a bunch of dimples all over the place.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
bollingball
« Reply #3 on: March 23, 2012, 05:37:54 PM »
Tug Be carfull who you listen to. Anyone who has done this should know you have to drill the stake marks. This is well documented. Use a drill the next size larger than the punch mark and only drill as deep as the mark If you do not you will continue to mess up the threads as you turn it out. You can do this without a drillpress but hold it straight Several post on this look at Thoughts of HondaMan or tips and tricks FAQ
Ken
« Last Edit: March 23, 2012, 06:25:59 PM by bollingball »
bollingball
« Reply #4 on: March 23, 2012, 05:39:54 PM »
Gonzo You are correct.
Ken
« Reply #5 on: March 23, 2012, 06:16:41 PM »
Ken
+1 If you do a search on wheel beaning removal. You will find some pics of homemade tools. When you o to remove it wiggle it left and right to dislodge any metal flakes from the drilling.
Offline Spanner 1
« Reply #6 on: March 23, 2012, 06:21:18 PM »
What ?...did  someone call me ?.....
Seriously tho'... prolly have to rap one of the holes with a steel punch and hammer to get a move on it... if you have a 'spanner' that fits, you will need to rap it with a hammer too, just to break the 'stake'.. good luck !
« Last Edit: March 23, 2012, 06:25:57 PM by Spanner 1 »
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #7 on: March 23, 2012, 09:12:35 PM »
I just did mine - front and rear.  Ken Buchanan told me about the drilling so I went for it - careful as I could be to drill only the retainer and not the hub-side threads, but I did get some of them on a couple holes.  The good news is I was able to clean these up pretty well with a thread chaser (basically a 10mm snap-on tap from their thread repair kit) and besides, even if "only" 90% of the receiving threads are in tact, that's plenty of bite for the retainer. At least I hope it will be.
I guess I'll find out -- I'm gonna put a tell-tale marker on it so I can more easily track any movement, but I'm also gonna stake it (once) and use a bit of locktite.
Getting the rear bearings out was not a fun job, but it's now a done job, and the new ones from All-Balls are in and looking fine.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline WhyNot2
  • I'm finally an
« Reply #8 on: March 24, 2012, 06:09:31 AM »
scribed........
« Reply #9 on: March 24, 2012, 06:35:25 AM »
You absolutely must drill out the stakes. There is no need to be careful of the threads in the hub side. Just set the drill bit, slightly larger than the stake size, in the stake hole and go down about 1/4 to 3/8. Clean/vacuum the drill waste away.   In the tricks and Tips there is a thread on DIY pin wrench, I'll look for it.
If the stakes are properly drilled out you will barely need the wrendh/pin tool. You will need one to reinstall however.
Not doing so often means you manhandle the retainer ring and destroy it and the hub. Many woeful threads here to that effect. If someone was able to turn the retainer without drilling the stakes, the stakes must not have been done properly. If proper, you will not be able to turn the retainer past the stakes without destroying something.
« Last Edit: March 24, 2012, 06:38:44 AM by MCRider »
« Reply #10 on: March 24, 2012, 06:43:00 AM »
« Reply #11 on: March 24, 2012, 06:45:38 AM »
Here's my favorite  ;) .
I started this thread with a wooden one, forget that. Others chimed in with better ideas. I finished the thread with the best one yet, so scroll to the bottom. 10 minutes about $3, and more leverage than you could ever want.
http://forums.sohc4.net/index.php?topic=40052.0
Offline Eydugstr
« Reply #12 on: March 24, 2012, 10:55:58 AM »
+1.  Make life easy.  The hub is made from a fairly soft aluminum, which makes it very easy to drill.  It also makes it really easy to booger up the threads if you try to unscrew it without drilling out the stakes!  Last time I used a really worn out dewalt cordless drill, still worked just fine.  The retainer is still available from Honda.  Once the retainer is out, wipe the inside with a towel to get rid of any shavings that may come off as you unscrew the old retainer.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #13 on: March 24, 2012, 01:33:22 PM »
That did it - smooth tapping them out once I drilled down about 3/16". Thanks fellas. Once again, this forum has saved my a$$ :)
« Reply #14 on: March 24, 2012, 01:40:29 PM »
God job. I didn't drill mine big enough and it was a nightmare. Get it right the first time and it's easy.
Offline 77hotrodhonda
« Reply #15 on: July 30, 2012, 03:06:35 PM »
hey guys. just got a new tire and bearings for my 77. Front tire btw. I had no problems getting the bearings out. but i dont have any sort of "spanner tool" and i got hasty being that im excited to get the new stuff together. needless to say i took the nut off with a hammer and a screw driver. Persistantly. Said persistance has led to the desctruction of this retaining spanner nut. does anyone know where i could find a replacement???
77 750K some might think I stole it cuz that's how I ride it
« Reply #16 on: July 30, 2012, 03:58:50 PM »
Reply #9 and #11 above will tell you what you want to know. Did you drill the stakes out before trying to turn the retainer? The retainers for the CB750 (what bike do you have?) are available from usual OEM suspects. Online like motogrid or your local dealer.
Offline bert96
  • past ride
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline gonzobrian
« Reply #18 on: August 01, 2012, 03:21:36 PM »
 Just found this tool,would love to have one,
http://www.ebay.com/itm/CB-750-REAR-WHEEL-TOOL-PEG-SOCKET-SPANNER-SERVICE-TOOL-CB750-HONDA-BEARINGS-hz-/261073130772?pt=UK_Motorcycle_Parts&hash=item3cc92bd514
Bert
Man that is nice.  I quickly bent the spanner wrench I got from Harbor Freight even after I drilled out the punch marks.
