Author Topic: Flaky ignition switch - CB750  (Read 1839 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: March 24, 2012, 04:57:43 PM »
My ignition switch has started to get twitchy. When I turn the ignition on, many times now the oil and neutral light don't come on until I wiggle the key back and forth. I don't see how to get inside these things to look for problems. Anyone know if it's possible to get inside to clean contacts?
Offline jakecb420
Re: Flaky ignition switch - CB750
« Reply #1 on: March 24, 2012, 06:08:53 PM »
yeah, take the switch off the bike.  pull back the rubber protecter on the back of the switch.  bend/pry 3 little dimples around the edge of the switch out.  the back plate with the wires soldered to it will come out.  it is spring loaded with little steel balls that will fall out, so watch what you are doing.  clean the contacts and put it all back together. enjoy a trouble free ignition switch.   hope that helps a little.
750K3 daily driver
76 750F project
74 CB450 donor
79 50cc honda express 2 moped
73 cb500-4
http://forums.sohc4.net/index.php?topic=73724.0
Offline mycb750k6
  • Rocketman
« Reply #2 on: March 24, 2012, 06:15:03 PM »
Thanks Jake. I'll try it this weekend. I love working with little spring loaded balls (Not!) This bike is loaded with little spring loaded balls, high beam, kill switch, blinkers, etc. I'm gonna take some pictures of this operation. How many balls and springs?
Offline jakecb420
« Reply #3 on: March 24, 2012, 09:43:51 PM »
looked like 2 balls(huh huh) and 2 springs.  good luck, its really not that hard, i practiced on one that i didnt have a key for first.
750K3 daily driver
76 750F project
74 CB450 donor
73 cb500-4
Offline mycb750k6
  • Rocketman
« Reply #4 on: March 25, 2012, 12:48:32 PM »
Got it. No balls, just two springs. Contacts were really bad so just cleaned them up and it's fine. Thanks for that. Here's my pictures.
« Reply #5 on: March 25, 2012, 01:17:21 PM »
Where'd your Ballz go --   ;D  ;D   Thanks for posting that pic of the inside though,its a mystery to most of us.
« Last Edit: March 25, 2012, 01:18:59 PM by ekpent »
Offline mycb750k6
  • Rocketman
« Reply #6 on: March 25, 2012, 01:30:50 PM »
Yeah it was easy once opened. A lot easier than a switch that's for sure. And it goes back together quickly too. And I'm sure there were no balls  8)
Offline jakecb420
« Reply #7 on: March 25, 2012, 04:42:00 PM »
i guess i made it up about the balls(huh huh i said balls again), i could have sworn one of them fell on the floor when i took mine apart.
750K3 daily driver
76 750F project
74 CB450 donor
73 cb500-4
Offline mycb750k6
  • Rocketman
« Reply #8 on: March 25, 2012, 04:45:01 PM »
One of your balls fell on the floor? :o
Offline Soulsk8r
« Reply #9 on: July 13, 2012, 05:36:42 PM »
Looks like this is my next project -- cleaning the contacts in my ignition switch.  Hopped on for a ride the other day, turned the key and .... Nothing!  Tried several more times, still nothing.  pushed her back in the garage and poured a little.  Next morning, turned the key and ... All is well!  So far so good, but I don't want this to happen again while I'm on the road.
Newbie rider, newbie vintage bike owner - Honda CB750K1.
